AI 355 Build Thread and More
Old Sep 4, 2010 | 06:07 PM
  #41
96lt1m6's Avatar
Originally Posted by MattSapp95_T/A
yea they are pacs with around 4k miles on them however they were on the last motor he blew to pieces and bent most of the valves so it may have been damaged from that...
We are going to replace them all just to be safe
good call
Old Sep 4, 2010 | 06:13 PM
  #42
SpeedDensityZ's Avatar
Originally Posted by Tireburnin
That sucks. Sorry to see that. You will get it sorted out.
Yeah, I know. I know the spring failure rate for these are less than 99%. I had all the springs tested when I had the valve guide and valves replaced but, you never can tell with springs sometimes. I'm just lucky nothing else was damaged, I had to pull it all back apart just to be sure.
Originally Posted by speed_demon24
Glad to hear nothing got damaged. How many miles were on the springs out of curiosity?
About 4K, actually a little less.
I'm so sick and tired of doing valve springs. Ghey. I believe the spring was damaged from the last motor blowing up too.
Old Sep 4, 2010 | 09:05 PM
  #43
MattSapp95_T/A's Avatar
Yea me too...at least you can put them on a bench though and won't be leaned over a car for 1.5hrs...LOL
Hell I still think mine may have a miss...I hope it was just low voltage.. It pulled to the shift light in 3rd though....
Old Sep 5, 2010 | 04:30 PM
  #44
97Z28SS's Avatar
That's massive carnage, I've known for awhile that all Eagle cranks are junk, my machinist told me to stay far far away from them. Does anyone know if the Scat cast cranks have the same problem breaking? I'm going to be rebuilding an LT1 soon to put in my 95 Chevy Blazer 4x4 and I want max torque from it so I want to stroke it on a budget. I'm going to be running Scat 4340 6" Pro Comp rods, SRP -16cc dish forged pistons and the 2 bolt block with studs and a main girdle. I also want to get the heads treated to an LE1 or LE2 port job and one of his cams or a GM 846 cam.
Will I be ok with a Scat Comp 9000 3.75" stroke crank for this na no N2o setup?
Old Sep 5, 2010 | 05:06 PM
  #45
SS RRR's Avatar
Village Troll
Pac 1220's.
How would YOU know!
Old Sep 5, 2010 | 05:30 PM
  #46
Originally Posted by SS RRR
How would YOU know!
prob cause he is running the same heads as the OP and that is the most common spring that AI runs on their setups....
unless you pay for their upgraded springs which are really expensive and have titanium retainers....but you can tell from the pic that the OP does not....
Just a guess....
Old Sep 5, 2010 | 06:49 PM
  #47
LT1's Avatar
LT1
Which valve springs do you plan to get?
Old Sep 5, 2010 | 07:07 PM
  #48
Going back with the same one after talking it over with AI
Old Sep 5, 2010 | 09:17 PM
  #49
I'm going to be running PAC 1220's again. I hope to have it back together either this weekend or next.
Old Sep 5, 2010 | 09:26 PM
  #50
better get to ordering parts bish...
Old Sep 5, 2010 | 09:29 PM
  #51
No doubt, I'm gonna order everything on Tuesday I think.
Old Sep 6, 2010 | 05:10 PM
  #52
Purple Poncho's Avatar
OT
I ran my Scat cast crank for 7 years up to 600rw and when it came out it was mint. I would use it again in a heartbeat.
The crank was bought in 02 so I can't comment on the quality now much as I am sure Eagle was not bad back in the day and then probably started cutting corners in quality.
Old Sep 6, 2010 | 05:27 PM
  #53
97Z28SS's Avatar
Thanks Purple Poncho, I think I'll get the Scat 9000 crank for my budget 383 since I won't be racing or spraying my 4x4 Blazer, I just want the max torque I can get for my truck.
Old Sep 17, 2010 | 02:57 AM
  #54
Well, I got the car back together and it seems to be running better than before. I still have an idle issue in gear though but, I found the IAC connector broken so I need to get another connector and fix it. I also did a fuel line relocation while I had the car apart.
Old Sep 17, 2010 | 06:19 AM
  #55
Rob94hawk's Avatar
The fuel line relocation looks great. Where did you thread it through?
Old Sep 17, 2010 | 10:20 AM
  #56
Tireburnin's Avatar
Nice job under the hood. Your battery is too big for such a quick car.
Old Sep 17, 2010 | 04:48 PM
  #57
-Thanks, I bought some AN fittings from Summit. QTY. 2 PN 640853 and QTY. 2 PN 640863. I had the hose made at a local hose supply shop. I drilled two 1 inch holes under the inner fender well about where the fluid fill res. for a 6 speed would be. Installed the grommets and pretty much run the lines in the stock location under the car and ran them over the brake booster in the back so it's hard to see. SPEEDINC. sells a real nice kit as well. I'm just a do it yourself kinda person.
Over the brake booster.
Hooked up under the car.
Ran along side the SFC's into the stock location under the lift pad behind the driver fender.
I know, I alteast need to relocate the battery. In a couple weeks I'm going to build my own alternator relocation kit to help clean it up some more. Prob. gonna do some wire tucks on the passenger side as well.
Old Sep 18, 2010 | 02:05 AM
  #58
[QUOTE
I know, I alteast need to relocate the battery. In a couple weeks I'm going to build my own alternator relocation kit to help clean it up some more. Prob. gonna do some wire tucks on the passenger side as well.[/QUOTE]
I have been telling you to relocate FOREVER!!!!
I may have some insight on the alt relocate....
And since I now take every opportunity I can to ***** out my alt, wire and fuel line relocates...
Hell find my high rpm miss and I will make and powder coat your alt bracket for you!!!!
Sincerely
Da Bish across the street....
Old Sep 18, 2010 | 02:14 AM
  #59
Well, I've spun this ignition system I have now to 7k without issues. We'll keep trading my parts out until it fixes it and then we'll replace that part. In the meantime here is an idle video I did this afternoon. I don't have a video camera and my digital camera only takes like 7sec videos. Here's 2 of them. Enjoy. BTW, the exhaust is Hooker LT's, ORY, and a Dynomax Bullet dumped.
Old Sep 18, 2010 | 09:39 AM
  #60
Tireburnin's Avatar
The disadvantage of relocating the battery is that you have to run a cut off switch. When I relocated my alternator, I bought an Ebay kit for SBC and then just cut bar to give it the correct spacing for an LT1. It was a cheap way to get it done, but you could easily build one for almost nothing with a bit of plate and tube steel.
