Need a board sponsor for LT1 oil system design
Old 10-27-2010 | 04:44 PM
Rob94hawk's Avatar
Exclamation Need a board sponsor for LT1 oil system design
I'll keep this simple. My LT1 engine if finally done and I need a sponsor from here who knows their **** with oil systems from pump to pan. Go. Credit card is waiting and your soliciting skills start here.
Am I forced to use the stock pan and windage tray now with the longer ARP bolts??
Old 10-27-2010 | 06:17 PM
tricked94camaro's Avatar
this should be interesting. i could use the info too.
Old 10-27-2010 | 06:22 PM
RamAir95TA's Avatar
What are you asking? Part recommendations?
Old 10-27-2010 | 06:31 PM
whytryz28's Avatar
Dry sump?
Old 10-27-2010 | 07:17 PM
Rob94hawk's Avatar
Wet sump. Pan, pump, and pickup. Preferably a blueprinted pump (Ed Wright's idea.) His idea was Moroso pan and blueprinted standard pressure Moroso pump.
I thought I read in one of the threads here that one of the sponsors did this. I dunno. Been through so many threads over the past month I may be wrong. Maybe I"m asking too much.
Old 10-27-2010 | 10:25 PM
wrd1972's Avatar
So is your engine wasted as the result of an oiling issue?
Old 10-28-2010 | 08:48 AM
Rob94hawk's Avatar
No. It's a fresh rebuilt 350 with a cam a little more aggressive than yours and I have no intentions on putting the stock oil pan and pump back on since it's going to be spinning close to 7k.
Old 10-28-2010 | 09:41 AM
SS RRR's Avatar
Village Troll
Canton pan (if Canton windage tray is used then run 5.5 quarts to avoid windage).
Moroso windage tray (if you want to run 6 quarts. Honestly 5.5 quarts is plenty fine if you don't want to mess w/ putting in a new tray).
If running factory bearing clearances then Melling 10554 (standard volume/high pressure).
Decide what pump you go with first before ordering a pan. Whatever company you go with will want to know what pump you have so they can accommodate it with their pickup.
That's it.
Old 10-28-2010 | 12:33 PM
jaycenk's Avatar
I run a moroso pan and you can only use a couple of pumps because you have to use moroso's pickup tube which is 5/8's. I went through hell tring to find the right pump to fit the right pickup tube. Here is the pan and the pump and pickup requirements are in very small print bellow the pan description. Read carefully. http://www.moroso.com/catalog/catego...?catcode=17001
Old 10-28-2010 | 12:38 PM
jaycenk's Avatar
Oh and my LPP long tubes did not clear the oil level sensor so I had to plug it. This is a pic with the sensor installed. sorry I don't have one with the plug I found for it but ace carries them for only 4 bucks compared to GM or summits 20
Old 10-28-2010 | 01:18 PM
gregrob's Avatar
Call Clayton
Old 10-28-2010 | 06:15 PM
Rob94hawk's Avatar
Now what? (see new pics)
Old 10-28-2010 | 07:50 PM
speed_demon24's Avatar
That's it.
5.5 quarts didn't do anything for my windage issue. And the 10554 pump is standard pressure and standard volume.
Old 10-28-2010 | 08:22 PM
RamAir95TA's Avatar
The Melling 10554 comes with the pink spring installed, which is the equivalent to the GM white spring, rated at 70#. It is higher pressure, contrary to what Summit says.
Old 10-28-2010 | 08:44 PM
Rob94hawk's Avatar
Joe, see my pics uptop? You have the same long bolts with ur Canton?
Old 10-28-2010 | 08:48 PM
RamAir95TA's Avatar
To be honest, I'm not sure. It's been 2 years since I've seen it. I want to say no though. I'm using the Canton windage tray.
Old 10-28-2010 | 08:55 PM
Rob94hawk's Avatar
Damn. Now I really don't know what to do.
Old 10-29-2010 | 10:28 AM
jaycenk's Avatar
Get a measuring tape out and measure from the block pan flange to the top of the bolts and make a phone call to canton, moroso, or who ever pan your looking at using.
Old 10-29-2010 | 12:03 PM
Rob94hawk's Avatar
Called Moroso and these are the parts recommended:
Pump: http://www.summitracing.com/parts/MOR-22101/
Pickup: http://www.summitracing.com/parts/MOR-24212/
Shaft: http://www.summitracing.com/parts/MOR-22070/
Pan: http://www.summitracing.com/parts/MOR-20185/
And to plug up the oil level sensore hole he said 1/2" thread.
Old 10-30-2010 | 10:08 AM
jaycenk's Avatar
to plug the oil level hole it's a special thread though. I cant remember what exactly but search summit and the forum for what thread bolt you need to plug it because it is something different than normal 1/2 inch threads. It's not fine or coarse. it something like m1.5x 20mm or something odd like that.
