383 horrible vibration above 1500RPM and throwing belts
Well This car that i got for a good deal is starting to become a pain in my ***.
Above 1500 rpm or so there is a horrible vibration and it is throwing belts. I found the crank hub loose the other day and torqued it down took it up the street real quick and noticed the vibration.
This is what i know about the car. 383 stroker, built t56, stock rear and suspension. That is about it. I was told there is about 5k on it since built and after removing the valve cover the inside of the head looks new.
Anyone recommend a good balancer? I am debating pulling the motor out and having everything checked etc. But i hate to do that if it is something easy.
Most of the aftermarket balancers are underdrive, so you're better off getting one from GM. Here's a bunch of them at Pace Performance.
http://paceperformance.com/i-5130581...-balancer.html
Also if the crank was internally balanced you need to make sure that there is a internally balanced flywheel. Running a stock flywheel will cause horrible vibrations. Dont know if this is your problem, but its def something to ask the previous owner/builder about.
If your serious about getting a good one go with ATI, I had a fluidampre tear up my timing gear. The ATI is really well built and I haven't had any problems with it.
Edit:You can also throw a MSD trigger on the front of it if you want to ditch the stock computer.
