What piston rings should I go with?
Did you guys use file fit rings or pre fit rings?
Also looks like Jegs has a decent oil pan on sale for $169 but doesnt look like it has an oil sensor hole in it.
http://www.jegs.com/webapp/wcs/store...Term=555-50223
The Moroso pan also looks pretty good
http://www.jegs.com/i/Moroso/710/20185/10002/-1
Canton looks cool but is pricey
http://www.cantonracingproducts.com/...on&key=15-242T
So looking at piston rings are these the right ones I should be looking at?
Hellfires
http://www.summitracing.com/parts/SLP-R-19100-35/
Total seal
http://www.summitracing.com/parts/TSR-CR3690-35/
perfect circle
http://www.summitracing.com/parts/PCR-3150036-030/
http://www.summitracing.com/parts/PCR-315-0072-035/
Hellfires
Total seal
perfect circle
Hellfires
Total seal
perfect circle
Hellfires
Total seal
perfect circle
• Better breakage resistance.
• Improved heat resistance.
• Better mechanical stress resistance.
• Reduced ring side wear.
• Reduced groove side wear.
• Longer service life.
Moe are the ones I linked the correct ones you would buy? Any negatives to the Hellfire rings? Would they hold up to street use. I dont want to refesh the motor all the time.
Im also looking at splayed caps for the build. Does anyone have the part numbers you used
Pros and cons of each?
