Gears, Cam, & Stall???
Old Jan 27, 2011 | 09:18 PM
  #61
rich5368's Avatar
Little off subject sorry but OP what kind of rpms are you turning on the highway at say 75 mph?
Old Jan 27, 2011 | 09:23 PM
  #62
LSWHO's Avatar
2800 with a 26" tire. About 600rpm higher than you.
Old Jan 27, 2011 | 09:24 PM
  #63
SpeedFreak123's Avatar
Damn Straight your off topic...
Jk... At 70-75 I'm at 2900-3100 RPM... I know, Its killer gas mileage, but that son of a b**** moves out in the city, and even on the highway from a semi-high roll? beat a 08 Civic Si the other day from a 55/60mph roll (I know its a civic but he's got "I/H/E/tune" and a 6speed)...
So, IMO, 4.10's are awesome for A4's
Old Jan 27, 2011 | 09:26 PM
  #64
LSWHO's Avatar
Originally Posted by SpeedFreak123
Ahhh, I see!!!
Ok. So Hotcam, 4.10's, and SS3600... Should be in the 12's easy Right!!
Absolutely yes. I ran 12.8 literally spinning the entire 60' with 3200/3.42s/cam
Old Jan 27, 2011 | 09:27 PM
  #65
Your new Sig is f***ing hilarious!!!
Old Jan 27, 2011 | 09:28 PM
  #66
Jesus. I ran 12.8 literally spinning the entire 60' with 3200/3.42s/cam
I dont get your point?
BTW, I will be running DR's.
EDIT: I didnt see the "Absolutely Yes", Did you edit after I replied?
Old Jan 27, 2011 | 09:29 PM
  #67
bowtienut's Avatar
Since someone brought this up > No, the SS3600 is not too much stall to have behind a 150 shot. I did it for years in a 4000 lb car, pulling 1.45 60's with the bolt-on LT1.
With a cheaper converter, I wouldn't go that high, but the Yank SS converters are very efficient and "hooked up".
Old Jan 27, 2011 | 09:31 PM
  #68
LSWHO's Avatar
I was saying with the mods you are planning if you don't run 12s with your DRs you have done something SEVERELY wrong.
also, that time I said was on DRs.
Old Jan 27, 2011 | 09:32 PM
  #69
rich5368's Avatar
Well I learned a lot today. Laughed a little too so I win twice. Thanks guys.
  #70
meine96ws6's Avatar
Do yourself a favor and pick a damn engine combination, i mean a solid cam that you can build off of.
Then get a stall to compliment the power range of it. There is a lot to factor as well, like mentioned tire size and WHAT TYPE OF CAR YOU ARE TRYING TO BUILD....
And, if your on cheap street tires it won't matter.. because your going to spin..
Old Jan 27, 2011 | 09:33 PM
  #71
Check my "Edit" in the post above, didnt mean to sound like a dick. LOL
Old Jan 27, 2011 | 09:35 PM
  #72
Lawhead's Avatar
Ahhh, I see!!!
Ok. So Hotcam, 4.10's, and SS3600... Should be in the 12's easy Right!! Cool. Sweet. No more arguing, even tho it makes me LOL!!!
Bolt on cars see 12's easy when you start getting that gas bill tell us how you build is going
  #73
I know what my set up will be now, thanks to the help of tech members!!!
4.10's , hotcam, and SS3600...
I wanna build a bad *** DD, that will see the track about 5 or 6 times a year!!!
DR's at the track, btw.
Old Jan 27, 2011 | 09:37 PM
  #74
gregrob's Avatar
Your rear diff is going explode
  #75
Lawhead's Avatar
A hot cam won't give you a "badass" DD IMO
Old Jan 27, 2011 | 09:40 PM
  #76
LSWHO's Avatar
Are you sure it isn't going live?
Yes, with 4.10s you run a significant risk of rear end damage. Be prepared to replace when you use sticky tires. May or may not "going explode" but be prepared for it.
Old Jan 27, 2011 | 09:41 PM
  #77
gregrob's Avatar
You've obviously never driven one. Hotcam cars are torquey and fun on the street. The stall gear and cam will be more than "DD" tires will hold. Id rock a hotcam w 1.7s all day long fir a true DD
  #78
LSWHO's Avatar
With what he's planning it'll be pretty badass. Not as much as a larger cam, but still a great performer.
Old Jan 27, 2011 | 09:42 PM
  #79
gregrob's Avatar
Will.
  #80
LSWHO's Avatar
Will.
Grace?
