Istalled Timing marks Dot to Dot?
cam timing gear should be 6 o clock and crank timing gear should be 12 o clock. and if your cam dowel pin is in the cam timing gear correctly it puts the cam at the correct position, it would be impossible for you to change it 180º and still be able to put the cam timing gear on.
I Installed my timing set DOT/DOT,witch just means i have to adjust the valve for TDC#6 first instead of #1. I was not thinking clear when i posted,I am just stressed out about all the money i have into this build and making sure its good from the go.As for the 180 i ment that i was 180 off of #1TDC because i installed the cam DOT/Dot instead of 12cam/6crank, witch put me at #6TDC instead. Lmfao Read the instructions to the gear set.... Thanks thats what helped me the most!
