can't get lt1 edit or scanner to connect to pull codes
http://shbox.com/1/DLC_wiring.jpg
Just to test it will it hurt anything?
1. I cleaned the aldl connector with carb cleaner, no go
2. Ran new wire from pcm d30 to aldl, no go
3. tested contunity through aldl connector to my scanner, no go
4. tested for both grounds, 12v battery, ect.., no go
5. put it all back together, turned key on plugged scanner in and it worked said no codes found, (due to battery being undone) Unpluged mass air started car to get it to throw a code, shut it off tryed to read codes again, now its back to not connecting.
6. Put a light bulb back into the service engine soon spot.
7. tried again still no connection.
8. right now the ses light is off (no code) still no connection.
9. Checked the pins and connections at the pcm look ok.
Any ideas??
http://shbox.com/1/xraycable.jpg
So Maybe the scanner won't connect due to using the wrong one, and maybe the Lt1 edit won't work due to using a serial to usb converter.??
