Fuel problem maybe?
Old May 3, 2011 | 12:20 PM
  #61
LT1FirebirdSLP's Avatar
You're throwing 16 and 36. And he got a bad PCM out of that equation. While not impossible, it seems rather improbable. IMHO I still suspect the OPTI. The car starts and runs. The PCM communicates with your scanner. I fail to get a bad PCM out of the equation. Bump... anyone?
Old May 3, 2011 | 01:12 PM
  #62
lethal bird's Avatar
Yea im pretty sure its not my pcm i can connect with tunerpro and i was able to scan it. Im pretty sure my opti is to blame here. Although i still dont know whats up with the pump priming twice.
Old May 3, 2011 | 01:27 PM
  #63
I'm lost on that one. Loose ground? Bad relay? The pump actually turns on, off, on again?
Old May 3, 2011 | 03:35 PM
  #64
Prime like normal, quits, then does it again.
Old May 14, 2011 | 01:30 PM
  #65
Formula.Fx's Avatar
It wasn't the PCM... now I'm out 400 bucks. Maybe its my opti? I'm having the car re-diagnosed at a certified GM service shop...
Old May 14, 2011 | 02:36 PM
  #66
It was my opti.
Old May 14, 2011 | 03:03 PM
  #67
Formula.Fx's Avatar
The GM guys said it was the distributor.. so Opti? Where can I get one for a decent price? They want to charge me $1300 for parts and service. I figure I'll just buy the part somewhere and fix it with some friends..
Old May 14, 2011 | 03:23 PM
  #68
95zguy's Avatar
Someone told me you can get a new opti lifetime warranty from Chandler Motorsports for 139.95. You might check it out.
Old May 14, 2011 | 05:22 PM
  #69
Formula.Fx's Avatar
https://ls1tech.com/forums/sponsor-s...ws-praise.html
According to this thread, Chandler isn't the best brand. They have had a lot of DOA optis. Anyone else have an opinion of a better option?
Old May 26, 2011 | 05:59 PM
  #70
Got good and bad news. Put the new ac delco on and it runs but its got a pretty bad misfire. Im losing all hope in the lt1.
Old May 26, 2011 | 08:46 PM
  #71
Ok i just a plug wire crossed all good now.
Old May 27, 2011 | 12:22 AM
  #72
97RedBird's Avatar
it might be the fuel pump. even with the noise that the fuel pump is making i had the SAME SAME SAME identicle problem and when i put new fuel pump it stoped doin it completely. but the rest of these guys on here have valid opinions as well.
Old May 27, 2011 | 12:28 AM
  #73
grunt1152's Avatar
My car is what seems to be in the early stages of this. I'm pretty sure its the vent in the fuel pump, its fine on a cold start but on a hot start it cranks for around 5 secs before starting. The vent isnt holding pressure once the pump has turned off. If I let the car set for a couple minutes it will do it on a hot start, however if I turn it straight off and straight back on it fires right up. Pretty sure its the vent.
Old May 27, 2011 | 11:02 AM
  #74
I thought it was my fuel pump but it turned out to be the opti.
Old May 27, 2011 | 04:47 PM
  #75
Formula.Fx's Avatar
I just replaced my opti and I'm still having issues. I'll have to check the wires too.
Old May 28, 2011 | 06:31 PM
  #76
Formula.Fx's Avatar
Opti was on wrong. *facepalm*
4 hours later and I'm good to go.
Old May 29, 2011 | 04:56 PM
  #77
Glad to hear you figured it out. I bought a new ac delco instead of an ebay opti like last time. Hopefully this one will last for a while or at least until i have everything to swap the 6.0 in it.
Old May 30, 2011 | 06:44 AM
  #78
SS RRR's Avatar
Village Troll
Where did you get it? I did a price check at my local dealer and they wanted $717.00. The entire parts department/service area was privileged to hear a big "**** THAT!" from me.
Old May 30, 2011 | 01:37 PM
  #79
^ i lol'd. I just bought the ac delco from summit.
Old May 31, 2011 | 04:16 PM
  #80
Formula.Fx's Avatar
Bought mine (AC Delco) on ebaymotors from AIT Electronics. $360.00, shipping free with 3-day ground. The packaging sucks but it worked fine.
