LTX Cylinder Heads
Reaper how do you plan on running 11 or 12:1 NA now and then going to a TT down the road? If you are planning for a lot of boost in the future it sounds like the heads you go with should be large chambers (65-70cc+). I guess if you found the right pistons you could bump that CR up now, but you'd have to then swap in blower pistons later. If you are going to achieve 11-12:1 CR NA with crazy dome pistons do not turn a blind eye to piston to valve clearance. The NA cam you pic would obviously factor in huge. When I was piecing my setup together I didn't even think to consider PTV clearance - I should have...
Michael
Michael
Why not a set of Allpro 23 degree with a badass CNC job, or 15 degree CFE heads that have cracked 1,000 HP N/A on 358 cubes...
Don't limit your options, it's only money.
Michael
Sounds like you're very ambitious. Hopefully you've got a deeeeeeeep wallet.
I talked to All Pro a few minutes ago, seems like just the heads will be around $3,500. I have to call back tomorrow to talk to Bob and he will give me an exact quote. I may stick with AFR since the whole head and valvetrain setup will be around $4,000. My pockets are not deep enough for $4,000 in heads alone.
I am waiting on AI to give me a call back on the valvetrain and cam so I can place my order there. I also need to get ahold of JE so I can figure out a piston for the build. I will be placing a order for the crank and rods through Flatlander, main caps through Competition Products, and then some parts and hardware from Summit. I already ordered the Strange S60 for the rear end and I need to find someone for a tranny. All and all I am starting to get on the ball with this. When I get all of my parts together I will start a build thread to document everything.
http://www.advancedinduction.com/AiPerfLT1.html
