Need spark plug help on AI set up
I got an AI385 stroker all forged runnin 11.3:1 compression should be around 430-450 rwhp. Need help choosing a plug. I don't know if I should run a tr6 or a br7ef. And plug gap? Should I be around .036-.040? I had a tr55 @ .040 but its breaking up at high rpms now. I got 1k miles on the motor, could I have messed anything up running too hot of a plug?
Fact is, in competent hands the OEM ignition system is very good.
Well he shouldn't have any problems on the TR55's either but he is... 11.3/1 only pushing what he is isn't creating enough pressure for the stock system to not fire the coil, BUT a coil going bad/weak would.
The piggyback does help with millage and def when using a colder plug. With the plug being recessed the multiple sparks help to make sure the mixture is burning. They also make sure the STOCK coil has enough energy to charge at high rpms.
I am running autolite 104s and I believe I set the gap at .35
Couple years ago my car started breaking up at high rpm (5500+) and it ended up being the Opti so maybe that is where you need to start troubleshooting.
And how old is the Opti? If you think it is the plugs gap a set at .020 and see if it gets better. To me it sounds like a optispark or a bad set of wires. Make sure a wire is not touching a header tube. It is so easy for one to touch and real hard to see.
Thanks for all the replies guys. I put in a new set of TR6's and it cleaned the top end right up. I had #8 plug foul for some reason it was very fuely, but after the change pulls like a **** all the way up! I cant believe the job AI does with their head/cam set ups. I've raced a couple head cam ls1's and a couple forged lt1 355's with head cam and I just pull on em like nobodies buisness!
The Opti is brand new GM unit so I was hoping that wasnt the issue and thankfully it wasnt. i need to get this thing Dyno Tuned now to see what kinda power she really has! At first I didnt have the TPS/throttle blades set at the right voltage ".067 volts" so I dont know if that kinda flooded it out or not but for now she's fixed
