new posi. any suggestions?
There is a LS1 Torsen forsale in the Classifieds..
https://ls1tech.com/forums/parts-cla...rsen-diff.html
I'm not sure if they have a Series 2 and 3 like the Auburns..
You are Correct.
This got me looking. I just bought a used 10 bolt and it appears to have a Auburn (cone) type posi...it is not rebuildable. I'm not sure if our cars also had Eaton (clutch) type posi which are rebuildabe, Randys ring and pinion sells some replacement clutch plate kits for them. And of course the Torsen is full of worms. lol.
I'll have to check back with the drivetrain shop to double check.
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
If any sort of drag racing is going to be done then a Torsen is the last carrier that should be used. The cases are thin and weak and have too many inspection holes. They are not designed to take any sort of shock to the driveline. For auto-x/road racing they are superior, drag racing then by all means use an Eaton or Auburn.
