Good place to buy bolts & gasket for headers?
I need a visual or a link here guys. Might be getting a set of headers & ory from a member on here and i need to know where/ what bolts & gaskets are good to get to finish the install. Links please? They're hooker comps if it makes any difference
i ordered the fel pro 1406 gaskets from ws6store a few months ago, they had the best price when i looked around. make sure you get 5/16" headed bolts, 3/8" won't fit unless you ding the primaries, thats the one part i didn't do enough research on so it bit me in the ***.
http://www.autozone.com/autozone/acc...er=723229_0_0_
I picked these up from autozone when I did my headers last year. I don't have anything bad to say about them, they work for me.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I used the bolts that came with the headers (pacesetters) and felpro 1406 gasket. Just make sure you use lock washers and retighten the bolts after a couple heat cycles. Do this until the bolts are tight after heat cycles. Don't do it while the engine is hot...
I tried stage 8s and did not like them. Putting those clips on = annoying.
