Leaving for the Shootout in about 3 weeks, everybody else ready??
#63
im hoping mine catches GMHTP's eye this year........id love to get a feature...........i worked my *** off on it this winter making it nice nice...........its a street/show/strip car that runs the numbers im hoping they may want it.........
last year..............
![](http://i919.photobucket.com/albums/ad38/quik95lt1/44355_1422087120668_1487400046_31119709_5106801_n.jpg)
this year...............
![](http://i919.photobucket.com/albums/ad38/quik95lt1/IMG_20110320_174337.jpg)
![](http://i919.photobucket.com/albums/ad38/quik95lt1/IMG_20110502_210157.jpg)
#64
OK, need some help here, probably need to post this in the forced induction site, but took the car for a drive for the first time yesterday, First the shop forgot to tighten the clamp for the hose that goes to the top of the water pump so the engine took a hot bath, but before that when I would accelerate slowly if felt fine but when I tried to get a little boost, the car would just like choke out, no boost what so ever, just start missing real bad. I had superchargers before but never a turbo so I dont know what to look for right now, any suggestions?
#65
#66
Gotya, OK my setup, was supercharged and went turbo so I have all of the supporting mods, the entire engine,pumps,injectors, motor are brand new. it is a front mount T76 with a 50mm Tial waste gate and a 50mm Turbo smart blow out. it is the headder type not log, the problem is when I accelerate slow it runs fine but if I try to get into a little boost, it hits a wall and just stumbles, No boost at all, FP is steady at that point.
#67
#71
No wideband, this is the first time out on the new setup, Yes it tuned for boost. but I will disconnect the turbo tonite and see how it does NA first.
#72
[QUOTE=moehorsepower;15281332]It was supercharged before, just went from a A1000 to dual walbros in tank, Plugs are gapped but its not even getting any boost yet to affect the plugs.
My bet is there is a substantial change right there. I'd check fuel pressure and what your fueling looking like. My bet is fuel is dumping at tip in somewhere.
#74
when it stumbles, FP stays the same, maybe goes up a lb or so but nothing drastic, the A1000 pushed a lot more fuel than the dual walbros so I wouldnt think thats the issue, I mean it would have to be dumping a whole lot of fuel to make it stumble that bad and have black smoke pouring out the rear, I did notice that even at idle, if I rev it up hard, at the upper rpm's say when it hits around 4000 it will do the same while in the drive way so?
#75
I agree with you on the fuel, I will double check the tune, could of forgotten something thrashing to get ready for the shoot out,It is maf, I made 722 RWHP with a maf on the supercharger, but I guess it could be bad,I guess the first and easiest thing to do is run it na to make sure its not like the opti, I will have to tone down the fuel but that will be no problem, When I pulled off the supercharger, I ran around NA with 75lb injector with no problems, Thanks for pitching in some ideas...
#77
It most likely has a huge boost leak with a MAF in front of the turbo and that behavior. Look for couplers with no clamps on them or blown off the pipe and just resting against it. I'd make a cap for the front of the turbo with an air valve in it. Using that, you can pressurize the system with shop air (compressor) and find/fix all of the boost leaks. Fixing little boost leaks has been good for 50+ rwhp on good running cars in my experience.
As for myself being ready for the shootout, I am on the horns of a dilemma. I just got offered a free spot at a private track rental the same day, along with the keys to 2 cool cars that aren't mine. I may have to skip the shootout even though I was really looking forward to it.
#78
![1poke](https://ls1tech.com/forums/images/smilies2/1poke.gif)
#80
Originally Posted by muddyjimmy
Not a problem. It's not like you would win the Street Stock class anyway.
