aftermarket oil temp gauge
Just in case you run low on oil what you gonna do with that sensor plus the bung is to big you would have to use reducers and that is not chances for a leak. And a temp sensor is supposed to be in a flow line to be accurate.
I am running mine into the pan as well. I have a moroso pan with a welded bung for a sensor though so thats not much help. I would just go above the oil filter and call it a day.
