9C1 Caprice
or, you can do like the rest of us and start off with a catback and an intake.
were you really strapped for money or something? Only reason I ask is becuase I know if it were me, I definitely wouldn't buy a car with 140k on the clock to use as a daily driver...
"strapped for cash" doesn't quite cover it. Anyway I've heard the cop cars with the iron heads will run forever. I hope so, although the tranny is starting to go out.
As far as body styles, the L98 only appeared int he F-Body in third gen trim. The Corvette was a bit harder to tell. The rear of the L98 Corvettes was inverted, and the rear of the LT1 'Vettes was more bubbly.
As far as the motors, the intake manifolds are a dead giveaway. Just look for the runners sticking out of the L98 manifolds. Other than that, LT1 intake filters are on the right side of the compartment (looking from the front of the car toward the car), and the L98 filters are toward the left.
I've worked on both motors, and they're pretty similar as far as the basics go. Main differences would be the L98's terrible intake design and super-constrictive heads, and the LT1's opti-spark distributor.
Hope this helped, you can find mroe specific years that the L98 and LT1s were in each car by running a search through the internet. There are literally thousands of write-ups on it.
For a civilian Caprice, the L99 motor has a lower output alternator, 100 amps compared to the LT1's 140amp alternator. You can see the difference by looking at the alternator cooling fan. The 140amp fan has blades on the inside, like a vented brake rotor. The 100amp alternator has traditional looking fan blades. If the car is any sort of special service Caprice (9C1, 9C6, etc.) then the above does not apply. All special service Caprices got the bigger 140amp alternator.
The 8th digit VIN code for the L99 is W. The L99 was standard on both the civilian and special service Caprice. The LT1 was standard on the Caprice wagon, Impala SS, Roadmaster sedan & wagon, and the Fleetwood.
There is a machined pad on the passenger side deck surface the is not covered by the head. However, it is obscured by the alternator. That's where the codes Darth posted are located. Those codes will give you the year and displacement of the block. If the block has ever been decked, these engraved codes are usually machined off in the process.
There is also a VIN derivative located on the driver's side rear of the block, above the oil filter pad. If the engine is original, then the VIN derivative on the block will match the 3rd, and 10th through 17th digit of the car's VIN.
The L99 used two cats like the LT1, but a Y-pipe connects the driver's side to the passenger side to a single pipe with muffler and resonator.
I have been told that on the L99 block, there is 4.3 in cast raised numbers on the side of the block near the core plugs. I can't remember which side though. Kind of like 360 or 318 being cast into the driver's side of Dodge blocks. No such numbers are found on the LT1 block
I've also been told that the '96 4L60E transmission case on the L99 is two pieces, with the bell housing being bolted to the rest of it. I don't know for sure if the is just for the civilian Caprice or applies to the special service cars as well.
The best VIN locations are
On the dash visible through the windshield
Federal Safety sticker on driver's door
SPID label on upper left hand side of decklid
If any of these VINs do not match each other, I'd start asking some serious questions about the history of the car. Also check the underhood emissions sticker on the radiator support to see if it matches the engine codes on the SPID and the model year of the vehicle.
For LT1 Caprices the SPID should have the QMU or QMV tire codes The LT1 engine requires P235/70R-15 tires. Check tire placard on the driver's door.
The civilian L99 Caprice also has a 2.93 rear end with rear drums, code GW9. The special service L99 Caprice has a 3.23 rear end with discs on a 9C1 or drums on a 9C6, code GU5.
