Started my LTCC conversion
These are the LS1 coil ends from Taylor, come in a pack of 8
Making my own wires, im using Taylor Spiro-Pro #73251 in red.
and LS1 boot ends Taylor # 46069
Taylor wire crimpers, 43390
I got a tip from one of my friends.. when assembling wires. They are a bee-atch to push into the plug ends with no lube, plus you dont want greasy wires. I was told to use Brake Kleen to lube them... it cleans the wires and terminals and dries clean. Good tip.
Here are some finished ones
Left over wire.. lots of it..
this is the LTCC box mounted on the driver side fender well.. i also used small little rubber O rings under the mounting points to help stave off vibration, some the the box can not have.
Here is how i mounted the coils, without using expensive $200 coil relocation kits.. or other expensive mounts.. mounted them right to the valve covers! NO modifications needed.
Close up
Engine shot.. only 1 side is done...
i should be finishing this up this evening and taking for a drive..
the brake Kleen i used is the non chlorinated kind... lucky me i guess but whats up with the regular brake kleen?
my car now rips to redline and idles/cruises just a bit smoother than with opti stock.
great idea mounting without brackets. Simple.
All the wiring for the coils is under the fuel rail covers.
