My AI heads and cam stoker goes 10.37 @4200 lbs
Went to a regional shootout yesterday. Made four runs and ended up with my best times to date. Car is a 1996 Impala SS with a all forged 385 ci LT1 stroker. AI heads and cam and TH400 with trans brake. Car is full interior with a 6 point cage. Also 4.10 gears full spool with c clip eleminators. Run was made on a 67/38 pill combo wet nitrous kit. and car weighs in at 4200 lbs. Here is the video of the run.http://www.youtube.com/watch?v=DoL1u53iqgA
Actually Jeff the car only 60ftd a 1.53 off the brake set at 2800. The car did spin off the line so that didn't help either. And thanks guys I know she has more. Got a few more T&T's left so will try to better these times
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Thanks for posting that video, Frank. And congrats again on your new best!
We wouldn't look to be that close if I were to pile another 300 lbs in my car
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
First time I've sprayed this H/C motor, and I'm excited about the potential.
Earlier in the day before the starting line deteriorated, it hooked and went a 10.78 on the 50 shot. You can see it spun and dropped the front end in the video. I was hoping to run it at Muncie tomorrow on their kick-*** starting line, but it looks like rain
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Your car is good for at least a low 10.2x on those same pills when you hook it up
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
