O2 sensors from GM parts direct or Rockauto
Its been a awhile since I have been on here.. But anyways as the title says I am looking to buy AC delco O2 sensors, but I have been reading some discrepancies about new designs and branding etc. Anways.. Which one of these places would be wiser to order from? I want to get as close to the original O2 sensors as possible.. I have been having an issue with a slight stumble at partial throttle and my wideband starts to spaz out when i hit closed loop.
GM pn #19178930
AC delco: AFS75
Here are the links to both sites.
http://www.gmpartsdirect.com/results.cfm
http://www.rockauto.com/catalog/rafr...artnum=2344012
I don't think the link to gm parts direct will get you to the sensors but the gm pn is listed above.
GM pn #19178930
AC delco: AFS75
Bosch O2 s are well known to be ***** with LT1 setups...
Now, that was a thing in the past and I have no idea if they have changed thier design or not, but it was well known. I believe the big issue had to do with how they referenced ground inside the sensor, ie, they used the case not the extra ground line, thus you would get drift if there was a ground differential with your headers (common issue, especially with well-coated ones).
Most of the NTK/AC Delco ones they were properly grounded internally and worked excellent. That is obvious since the new AFS75 sensors ARE NTKs now.
www.getgmparts.com for Delphi sensors, basically the same thing as AC Delco.
They're usually cheaper than gmpartsdirect.com
