Mild build LT1 exhaust question on a 94Z
The previous owner cut the stock pipes all to hell taking out the tranny, now it's just a mess, the cat is junk anyhow and I am getting outragous prices to replace stock pipes. I will need everything from the manifold flanges back. At this point the engine is still with manifolds but I have headers up on the shelf. What is the best bet to put my car back together either on the cheap or the most cost efficient way?
The reason for not switching the manifolds, I am not sure in the future if I will go spray or boost. At this point I just want to get the basket case back together and go from there.
Yes on inspections, but visual only, no emission tests. Don't really care anyway.
Eliminated the air, smog egr.... No cat is fine.
The headers I have are emissions compliant. Since I don't need them to be emissions legal I figured no need to molest them to get them to work.
Wife bought them for me for Christmas so I better be sneaky when I sell them.
Anyone have a stock y pipe or headers and y-pipe for cheap? Shorties are fine
Open to any suggestion that does not need cat.
Too bad your so far from TN or I have all the factory stuff just laying around albeit a bit sliced up but that isn't too hard of a fix. or I would pretty much let you have my stock stuff.
If your not worried about emissions then I would highly recommend doing headers with custom exhaust. I have ceramic pacesetter longtubes with custom Y pipe with a magnaflow merge and a dumped magnaflow 4x9 before the axle. I have about $700 invested including poly motor mounts.
Back to the top.
Decided to stay with stock manifolds for the rear mount turbo build. I am looking for an aftermarket or stock Y pipe that will bolt up to the stock manifolds.
What do ya got............
Anyone with a stock Y out there? Happy to pay what the parts are worth plus whatever in shipping.
I am wide open to suggestions on which is the better way to go for a rear mount turbo with a 70mm .96.
Let me here it.
