vavoline racing oil 50 ? anyone ?
i just got a 383 stroker lt1 10 sec car on 200shot, and the previous ower told me to run valoline racing oil (weight)50..isint that toooo thick of an oil? or will it be be ok to daily drive and poddible race every once in ,thsnks alot for you help inadvance...
IS ANY ONE RUNNIG THAT?
will it do any harm to the motor..
thanks ,joe
thanks ,joe
Im running valvoline vr1 20-50 in my motor due to the loose clearences.No problems so far with it.My engine guy also told me to switch it out for something a little thinner in the winter and run the 20-50 in the summer.
if the previous owner said use it, that would indicate the motor was set up with wider bearing clearances than stock. Often done on re-build performance motors and then a thicker oil is recommended. Ideally he had a build sheet that notes bearing clearance.
These type of motors often come with HV oil pumps. Motors with stock bearing clearances should not use HV pumps or thicker oil as to much strain/wear on pump drive gear results.
as stated by everybody above has alot to do with clearances and how the motor was built............i run the valvoline VR1 20w50 in mine ive never had an issue in 7 years.......ran it in my 355 for 3 years and this motor for 4 years.....never broke a pump drive or shaft.......run a good gear and a good pump drive shaft and your fine.......im 55psi @ 8000 rpm and 25psi idle........all you need
As already brought up by two of use "what pressures is it running at?".
IMO if it sits at 60+psi at cruise and above it is just on bypass and then the thick oil is a mistake. I wouldn't just take a previous owner's word without applying a little common sense of my own. Then again I probably wouldn't buy a built car unless I knew a LOT about it because so many are halfassed so badly.
