93 vs 95 lt1?
Old Mar 12, 2012 | 12:52 PM
OnlyACamaroCanbeAZ28's Avatar
Default 93 vs 95 lt1?
Posting this for a friend who just bought a 95 z28. Motor has a front seal leak and needs to be gone over. He has found a lt1 from a 93 that has heads, cam, and has been bored .030 over. For the money its a better deal than pulling his motor and redoing everything. The motor is from a 93 though and I wasnt sure if there was any differece in anything motor or wiring related from a 93 to 95 with 93 being the first year. Im not very familiar with the Lt1 in general but this is one of the better tech forums so i thought id post the question for him and see if anybody had any info on it. Thanks in advance
Old Mar 12, 2012 | 01:04 PM
MasterTomos's Avatar
The 93's were kind of a different year from the rest of the LT1's. Im not sure on all of the specifics, but I know the '93 had:
Speed Density tune (no Mass Airflow/MAF)
Non-Vented Optispark
Different intake manifold
Different fuel rails
Different fuel line setup
And different O2 censors if I remember right
Im sure there is more differences too
Old Mar 12, 2012 | 01:12 PM
Valkyn's Avatar
If you just swap over the long block and put all the 95's accessories on it (opti MAF etc) there shouldnt be any difference unless im forgetting something.
Old Mar 12, 2012 | 01:19 PM
TSAEB's Avatar
Like mentioned above also u need the 95 intAke manifold and timing cover.
Old Mar 12, 2012 | 01:53 PM
93M6Formula's Avatar
Here is a thread I started 4 years ago on this topic, Has a lot of good info pertaining to 93 LT1 differences.
https://ls1tech.com/forums/lt1-lt4-m...4-97-lt1s.html
Old Mar 12, 2012 | 01:59 PM
Just a few things though that you will need to do for sure (some have already been mentioned.)
Swap 95 Intake, fuel rails, timing cover, opti, adjust dowel pin on the 93 cam (not exactly sure on the specs), Oil pressure sensor is located by the oil filter on the 93 motor compared to the 95 which is behind the intake manifold. I think i'm forgetting a few items yet.
Old Mar 12, 2012 | 02:50 PM
Thanks. I looked for something like that but nothing came up. Guess i was using the wrong keywords.lol Ill pass the info on to him and see what he wants to do.
Old Mar 12, 2012 | 03:09 PM
Yep that should help him out a bit. I would like to get that stickied possibly or I'll make a new one actually with as much info as possible for all LT1 years. Not sure if we have one or not?
Old Mar 12, 2012 | 07:25 PM
would there be any problem using a non vented opti on a vented opti car?
Old Mar 13, 2012 | 08:21 AM
Yes, that is why you need to change timing covers because the non-vented opti is a spline drive and will not fit on the 95 cover. Also I believe the plug is different between the 2 optis. Just use your 95 opti and timing cover. But make damn sure the dowel pin on the 93 cam is at the right length otherwise you will have major problems.
Old Mar 13, 2012 | 10:31 AM
How can I tell when the dowel pin is at the exact length? U suggest grinding it down?
Old Mar 13, 2012 | 10:35 AM
I can't remember the exact length it needs to be, let me check I know i've seen that info 100x on here before.
Old Mar 13, 2012 | 10:44 AM
Found it!
On late 94-97 LT1s, the dowel pin extends .625"
92-early 94 cam dowel pin length should be .340"
Also just to be absolutely sure, use a digital caliper if you have one and measure the pin on the 95 cam and then match that to the 93 cam. That way it won't be too long and ruin the Opti or too short and not drive the Opti.
I believe you can tap the pin in with a RUBBER mallet (I don't recomend a hammer unless you're very careful). It can be a pain in the *** to pull back out sometimes though.
