Fel pro 1406 problem
Flow numbers are NOT the measure of a head, they are more for marketing than to indicate true function. A steady state flow test does not measure how the port works in a running engine. Ever stop and think about how many times per second the valves are opening and closing at 6000rpm?
as for exhaust ports i finish the ones i do very fine just like the combustion chambers......helps cut down on carbon sticking to the walls and efi intakes i finish finely the same (220 grit plus some other tweaking).......and ive had all great resutls on the ones ive done....keep in mind its not a generalized statement what i said above......different ports are designed with different characteristics in mind and the finish plays a role on how they can act..... Last edited by quik95lt1; Mar 29, 2012 at 07:46 AM.
I wouldn't really call 220 polished though either.
I remember a few years back someone nearly mirror polished a whole lifter valley to improve oil return, so defining "polish" like you did saying you use 220 was a good point to make, one guy will use 220 the next will aim for mirror finish.
