Gm Cam 19244485 NOT GM847
The GM performance parts cam #19244485 is NOT for LT1/LT4's. This cam is for Gen 1 engines. Ordered one got it in and it will not work with the opti spark. I have already contacted Summit about this cam being mislabled.
I ordered that cam from a local chevy dealer 2 monthes ago and it fit fine. My opti dowel only goes through the cam gear but not into the camshaft itself. My 94 Z28 has been running okay despite stock tune.
What I meant by okay is that it runs and drives I know its not going to run 12 seconds in the quarter mile. It does pull pretty hard in the high rpm range though! I am buying Tunercat in a week or so.
just ordered my GM847 from a dealer as well and your right it does not have the hole in the center of the cam for the optispark but if you have a lt1 with a non vented opti like my 93 you dont need the hole so the cam will work
