efi connection people won't start throwing code
Old May 12, 2012 | 09:31 PM
z28rob18's Avatar
Default efi connection people won't start throwing code
car is throwing a code 1336 crank relearn. Does anyone know what this is or why? seems like it wont fire from timing. How can i fix it?
Old May 12, 2012 | 09:36 PM
tt383lt1's Avatar
there was a post a couple weeks back about this. does is start up good?
Old May 12, 2012 | 09:39 PM
z28rob18's Avatar
wont start. stumbled once backfired and after that seems only one cylinder fires
Old May 12, 2012 | 09:41 PM
tt383lt1's Avatar
the only time i have ever done relarns is with the car firing. but you might be able to do it while cranking the bitch for a while.
do you have crank and cam singles?
Old May 12, 2012 | 09:45 PM
z28rob18's Avatar
how would we know if we have crank and cam signals? and what is a relearn? car wouldn't start so we hooked the diagnostics reader up and that was the only code. Were clueless as to what it is
Old May 12, 2012 | 09:51 PM
JasonShort's Avatar
Moderator
What base program did you flash the PCM with? I used the "411" PCM, started with a stock LS1 F-body program, tweaked it for my cubic inches/injector, added in timing across the board, uploaded that program to the PCM, and the car fired up immediately.
Old May 12, 2012 | 09:54 PM
tt383lt1's Avatar
you have a nice scanner. at work i have a snap on soltice. but you hit relearn on the scanner and bring the rpm up for 30 sec or something i cant remember 100%( it tells you why your doing it) and it done after that.
and you need a scanner with live data to see if you have singles from the crank and cam. but i couldnt see a car not running just by a crank relearn. i think your not getting a single from one of them or the tune
Old May 12, 2012 | 09:56 PM
tt383lt1's Avatar
how did you switch the firing order? in the harness or pcm
Old May 12, 2012 | 09:57 PM
z28rob18's Avatar
is this signal the reason it's not firing? cause we aren't able to get it fired
Old May 12, 2012 | 10:01 PM
tt383lt1's Avatar
you need the crank and cam single to get a injector pulse and coil pulse. if you dont have them the car will not fire
on my 24x swap i had to get the lower timming sprocket thayed down to get a crank single. i called efi and they said aftermarket cranks are all diffrent and to make sure the wheel is right in the middle of the sensor hole
take the crank sensor out and see it the wheel it dead on in the middle of the sensor hole if not your probley not getting the single
Old May 12, 2012 | 10:02 PM
z28rob18's Avatar
I bought the computer with a tune from pcmforless. The coils were from an LTCC setup i bought from someone and they were labeled what cylinder each was for. You think we have the coils switched up and thats the timing issue?
Old May 12, 2012 | 10:05 PM
tt383lt1's Avatar
hook a timming gun up on the spark plug wires and that will tell you if you have spark ( it might be on the wrong cylinder but you will know) and you have to follow the wires in the coil harness to see which one goes where. i rewired mine so i know mine were right. a
nd did you switch the firing order in the harness or ecu. you can do it eather way i did mine in the harness.
Old May 12, 2012 | 10:15 PM
z28rob18's Avatar
left the coil harness the same from the LTCC setup we didn't change anything as far as firing order. Just plugged the ltcc harness into the new wiring and then plugged them in the order he had it. guess we'll see with a timing gun
Old May 12, 2012 | 10:18 PM
tt383lt1's Avatar
the firing order from a ls and lt are diffrent you eather have to change it in the harness or ecu. if you didnt do eather thats your problem
Old May 12, 2012 | 10:22 PM
z28rob18's Avatar
alright there's our issue i believe. what we need is to take the ls firing order and set it up for the lt
Old May 12, 2012 | 10:31 PM
tt383lt1's Avatar
yes. i can have the wiring up for you tomorrow. u need to switch 4 cylinders around i beleive. or it might be 3 ( injectors and coils)
but take the ls firing order and put it on the lt cylinders does this make sense
Old May 12, 2012 | 10:35 PM
z28rob18's Avatar
our harness was the plug and play and the injector connections only reached to certain injectors and was labeled. so shouldnt it just be in the firing order?
Old May 12, 2012 | 11:26 PM
tt383lt1's Avatar
whos harrness are you using?
Old May 13, 2012 | 12:09 AM
z28rob18's Avatar
Were using efi connections harness. And the coil harnesses r from the ltcc I had but didn't use
Old May 13, 2012 | 12:49 AM
tt383lt1's Avatar
then the harness is good. i would double check the coil harness to make sure. and also check the crank wheel and sensor line up if the harness is good
