car has a slight shake at high speeds
Old 05-20-2012 | 10:43 PM
Lil'Felt's Avatar
Default car has a slight shake at high speeds
hey guys what could cause a shake at high speeds, 90+ i can feel it through the seats and stick shift. it goes right away around 75-80? was told that it could be the drive shaft but multiple opinions is always better then one.
thanks fellas.
Old 05-21-2012 | 12:59 AM
HarleyZ28's Avatar
I would guess it's the drive shaft.
Old 05-21-2012 | 01:11 AM
402GOAT's Avatar
i would think you would be able to duplicate the vibration at the same rpm no matter which gear or mph you were at if it were the driveshaft. if you can't then i would do a good tire inspection, checking for cupping or uneven wear and tread condition. followed with a rotate if need be and for sure a balance job.
Old 05-21-2012 | 01:33 AM
HarleyZ28's Avatar
I have heard of many Lt1's drive shafts starting to shake at the 90 mph + range. You could take it off, take it to a shop and have it balanced, or just buy a aftermarket one that can hold more power.
You could have it off in 10 minutes, very easy.
Old 05-21-2012 | 07:18 AM
Lil'Felt's Avatar
Who makes a good one rated for at least 600-700hp
Old 05-21-2012 | 08:02 AM
SS RRR's Avatar
Village Troll
http://www.dennysdriveshaft.com/c1_n...iveshafts.html
Old 05-21-2012 | 09:58 AM
wrd1972's Avatar
thanks fellas.
Stick or auto?
Old 05-21-2012 | 11:12 AM
Lil'Felt's Avatar
It's a 6speed
Old 05-21-2012 | 11:59 AM
RamAir95TA's Avatar
Old 05-21-2012 | 12:08 PM
pillarpod's Avatar
Could be a tire needs balanced
Old 05-21-2012 | 12:45 PM
wrd1972's Avatar
Most of the time, its a drive shaft imbalance. Once you have ruled out the DS and the other simple obvious things, look here:
https://ls1tech.com/forums/lt1-lt4-m...vibration.html
Old 05-21-2012 | 02:04 PM
Lil'Felt's Avatar
How do I check for ds imbalance?
Old 05-21-2012 | 02:31 PM
wrd1972's Avatar
Remove, take it to a shop that can put it on a balancer and determine if its balanced or not. Short of that, no other way to accurately do it.
Old 05-21-2012 | 02:43 PM
Lil'Felt's Avatar
Can they balance it or would I have to purchase a new one
Old 05-21-2012 | 02:51 PM
wrd1972's Avatar
It can be re-balanced by the shop.
Old 05-21-2012 | 03:30 PM
Lil'Felt's Avatar
Cool thanks guys!
