throttle sticking after engine is warm?
also does cruise control not work with the tb that i put on?
For 52mm you would have been VASTLY further ahead to go with a rebored stocker as all the aftermarket TBs have issues, the Holley are just more substantial issues than most. If spending the coin on an aftermarket TB then 58mm is the only way to go.
Was the LT4 manifold destroyed to fit the LT1 heads? The only thing that separates it from an LT1 intake is more material above the ports to seal to the taller LT4 head ports. That extra material will stop it from seating right on LT1 heads unless the intake is ruined as an LT4 manifold by milling the material off or the heads have some of the valve cover rail ground off to make room for the LT4 manifold, then after all that you just have a red intake that is internally the same as the later small port LT1 intakes just like your car came with.
If the heads or intake were modified to fit eachother than that work could also be suspect and a potential source for a vacuum leak.
96capricemgr- i got the holley tb for $80 from a friend that is getting out of the lt1 crowd and into ls1 i still have the stock tb sitting in the shop. the lt4 manifold was put on by previous owner along with different heads(not sure what kind and he didnt know either but said they were ported and on a 93 firebird that was a strip car before he bought them). i wish he would have had the lt1 intake and heads still when i bought the car cause i would have just ported both and been done with it. about 3-4 months ago i had a major vacuum leak in the back of the intake and had to replace the gaskets. i know for sure that there are no leaks from the intake manifold now
