1.7 rocker questions
ok so i think i want to do rockers install. i have a 94 LT and i have cai, headers, and full exhaust. Ive been reading about rockers etc. at first i was gonna go 1.6s with lt4 springs. then i stumbled upon 1.7s, im not going to cam this car im on college and its my dd so i wont be re buying parts if i go 1.7s.
what exact kind of and brand 1.7 rockers should i get?
what springs should i get to accommodate the 1.7s?
do i need guide plates? if yes what kind?
thanks for all your help
Posted from LS1Tech.com App for Android
Im no expert, but I would have to think that you would see more Gains from some other kind of mods with that same money then you would with just doing rockers and springs.
I could be wrong but.................
Look into the crane spring kit. They be plenty for what your wanting to do. Yes run guide plates and nsa rockers. Go ahead and upgrade to 7/16 stud while your at. Youll probly gain 10 to 12 wheel running 1.7
If I was going to buy a set of 1.7 rockers today they would be Scorpion 1.7 NSA 7/16 stud, and use these springs
http://pitstopusa.com/i-5072990-howa...d-878-i-d.html
Originally Posted by SS MPSTR
OP, if you're dead set on doing it, I have a set of 8 I'll let go cheap. I tried running them on the exhaust side at one point, and since switched back to a full set of 1.6's.
is it worth me doing 1.7s or should i just stick to 1.6s
NSA because of too many horror stories of SA rockers walking, its just very cheap insurance. SA rockers are not recommended to be spun past around 6200rpm which is fine for a stock cam or a Hotcam, but not much else, and I posted those parts assuming in the future you will do a cam swap.
[quote=9D4Z28] Quote:
ill prob go with the 1.7 nsa 7/16 stud scorpion set up you recommended and the springs you recommended. thanks.
is there anything else i should know? wont be any fiment problems with valve covers right?
I have over 4 years on 1.7's without issue, my setup is;
26918 Comp beehives
787-16 Comp retainers
stock locks and seats
Trickflow 7.2 chromoly pushrods
Trickflow TFS-30400623-8 guide plates
ARP 134-7103 studs
Scorpion 1026 rockers
The only issue was on installation the pushrod was very close to the bottom of the U. I used a die grinder to deepen it .060" or so. Just the swap from 1.6 Promags to 1.7's gained me 10 rwhp on the dyno. At the track from a best of12.97 to my current fluke of 12.82 et. It also raises the stock cam power band quite a bit. It leveled off around 6200 rpm on the dyno.
I run the tall Proform 141-131 covers-no baffles, with the alt in the stock location.
26918 Comp beehives
ARP 134-7103 studs
26918 Comp beehives
ARP 134-7103 studs
26918 Comp beehives
ARP 134-7103 studs
ok so if i use the same bee hive springs as you, guide plates, and scorpion rockers i should be all set ? also are your rockers nsa? oh and will i neef taller valve covers?
There has never been an issue with the race series.
Originally Posted by DVS LT1
Its been a while since I looked at this, and I've had a few on a sunny patio today, but don't the stock LT1 heads accommodate a 3/8 stud? How do you upgrade to a 7/16 unless the head is setup for that?
I recall the LT4 heads taking rocker studs that were 7/16 at the bottom (fastened to the head) but were 3/8 at the top of the rocker - to accommodate 3/8 rockers. Or was it the opposite. Maybe I shouldn't be saying anything...
I agree that a 1.7 ratio is opening up a can of worms in terms of sacrificing valve train stability vs whatever gains you could hop to reap. Unless you are talking about a very expensive and sturdy shaft mount 1.7 rocker like for a solid roller setup. Whatever you do (1.6 or 1.7) don't cheap out. Go NSA, 7/16, and there's plenty of evidence that favours steel over the lighter weight aluminum models...
also what are the pros and cons of aluminum versus steel?
I tried scorpion rockers once and hated them. They made a ton of noise and just didn't fit right. They will however fit under your stock valve covers if you go with them. As gregrob was saying Comp hi tech FTW
