i got my tune today from pmcforless help
pmcforless and now my car is over heating do i need to get a transcooler a tranny tune up or coolant flush i need help i have 4.10 gears a longtube headers
Posted from LS1Tech.com App for Android
What really irritates me is when people are giving you things to check and you keep going on about some bullshit you think could be wrong. Listen to the people, check your ****. Why in gods green earth would your car overheating on your ENGINE TEMPERATURE which is in the HEAD, be related to the TRANS overheating? Heyzues Christ.
unplug .the connector on the front of the WP...do both fans come on? they should
since your problem happened after the tune that may be the issue...but to the tuners benefit check your cooling system **** first
you chose the tuner...one i would not have
i have 4.10 gears and a pcm for less tune the fans are on and thw car smoke on the highway once i pass 3000rpms i new two this stuff
ok thanks everybody i found the problem it ws a oil leak from the valve cover i guess it must of pop the seal when i test driven it the day i got the pcm back ....and all fan are wire to come on when car start
Originally Posted by MillerTime85
So you saw some smoke and thought it was overheating but didnt look at engine temp gauge to actually see? oh and op did you check the to see if fans come on?
