LE2's???
Old Aug 28, 2012 | 05:00 PM
93_transam's Avatar
Default LE2's???
Is anybody running LE2's on a stock bottom end? What kind of cam are you running, what other mods do you have and how much power are you putting down?
Old Aug 28, 2012 | 05:41 PM
1995 T/A's Avatar
Yes, I am running your mamas cam with no other mods, and putting down some of its power.
Old Aug 28, 2012 | 06:15 PM
1995 T/A's Avatar
just kiddin Billy
Old Aug 28, 2012 | 09:16 PM
joeZ96's Avatar
https://ls1tech.com/forums/lt1-lt4-m...-goes-10s.html
Old Aug 29, 2012 | 12:11 AM
93_transam's Avatar
Thats awesome. way to show how badass an lt1 can really be when done right, and on a stock bottom end! how much hp are you making with that setup
Old Aug 29, 2012 | 04:54 AM
RamAir95TA's Avatar
You can spray anything into the 10s nowadays.
Old Aug 29, 2012 | 09:09 AM
96capricemgr's Avatar
https://ls1tech.com/forums/lt1-lt4-m...1-119-7-a.html
Stock shortblock b-body has gone 10.9 NA so like Joe said spraying into the 10s is no big deal.
Hell they have someone running 9s on a stock shortblock with spray.
https://ls1tech.com/forums/lt1-lt4-m...ck-record.html
Not trying to make you change your mind, just offering some perspective on your thoughts that high 10s on the jug is "awesome".
This is besides the fact that asking IF anyone has run LE2s on a stock shortblock is just plain a stupid question about as intelligent as asking if anyone has ever tried putting headers on an LT1. I think the question you wanted to ask is what results have people had with LE2s on a stock shortblock. For that you could go to the sticky at the top of the forum with the fastest LT1s and do an "LE2" filter and see a lot.
Old Aug 29, 2012 | 11:58 AM
93_transam's Avatar
I wasnt asking if anyone has ever run LE2's on a stock bottom end. i was looking for the people on here who have run them on a stock bottom end to see the results they got. And who cares if he sprayed into the 10s. 10s are awesome anyway you get there.
Posted from LS1Tech.com App for Android
Old Aug 29, 2012 | 12:45 PM
96z28_lt1's Avatar
i run le2 heads on my stock shortblock with an xfi280 comp cam, ported intake bigger throttle body and injectors, not sure on exact power but around sea level i should atleast be seeing high 300 rwhp with my m6
Old Aug 29, 2012 | 03:44 PM
93_transam's Avatar
What is your 1/4 mile time and mph?
Old Aug 29, 2012 | 05:38 PM
96z28_lt1's Avatar
haven't been to the track yet, i've come into som thigns that need fixing, also getting out of the military and any times i would have is over a mile high sea level, car runs and pulls great though compared to stock, juust letting you know that le2s can run on a stock shortblock and a lot of people have gotten awesome times with them, i know a guy bac home who has hit 11's with just top end done, not sure of his cam though
Old Aug 29, 2012 | 10:19 PM
joeZ96's Avatar
Show me a 10-second LTX-powered F-body or B-body which doesn't have a lot of time and money behind it to get it there, especially full weight. It still takes some work.
Old Aug 29, 2012 | 10:29 PM
Originally Posted by 93_transam
is anybody running le2's on a stock bottom end?
Old Aug 30, 2012 | 01:19 AM
93_transam's Avatar
Exactly. its hard for some people to understand that. you have a good setup.
Old Aug 30, 2012 | 01:26 AM
93_transam's Avatar
I know people run them on a stock bottom end. By asking that question, i was simply asking the people who are running LE2s on stock bottom end, what setup they have and how much power or what 1/4 mile times they are putting down.
Old Aug 30, 2012 | 03:54 AM
The Batman's Avatar
From what I have seen over the years...Stock shortblock with LE2 heads and cam and all supporting mods cars are typically running 400-430rwhp, and mid 11's NA.
Old Aug 30, 2012 | 05:19 AM
RamAir95TA's Avatar
*raises hand*
Old Aug 30, 2012 | 05:37 AM
Dave357LT1's Avatar
^^^ I guess a lot of money is relative? It took some time also if I remember correctly
Old Aug 30, 2012 | 05:51 AM
RamAir95TA's Avatar
My build actually only took 6 months. It was a rusted piece of junk in December 2008 sitting outside with no heads/intake and in May 2009 it was running deep 11s.
I had alot of leftover parts from the previous builds so that helped.
There's nothing fancy about my setup. Budget forged crank, budget used forged rods/pistons, off the shelf AI 200cc heads, off the shelf cat-back, etc. Still got the good-old 8 year old AC Delco opti, power steering, full interior, heat, etc.
Granted since then I've invested alot of money into the suspension but the motor (capable of 10s out the gate) remains untouched since then.
Old Aug 30, 2012 | 09:50 AM
BOLO's Avatar
I run LE ported LT1 heads with lightweight LS1 valves. See sig below.
