header gaskets problems
Old Oct 21, 2012 | 02:56 PM
lt1needingboost's Avatar
Default header gaskets problems
just spent a hr searching and going thru all seven pages of threads looking for a answer to a question ive seen on hear alot of times. So hear it is best header gaskets and bolts for a 383 lt1. Just want something that works dont care how much it costs. Thanks in advance for ur time.
Old Oct 21, 2012 | 03:32 PM
RamAir95TA's Avatar
ARP 1" SS bolts and Felpro 1406 gaskets here.
Old Oct 21, 2012 | 03:50 PM
Default gaskets
thank you very much i hate asking the ?s that have been asked before but cld not find a definitive answer w search. Thank you for ur time.
Old Oct 22, 2012 | 10:23 AM
katz_2003's Avatar
Runnin the same set up here. I would recommend 5/16 head bolts...
Old Oct 22, 2012 | 11:01 AM
guppymech's Avatar
I also use the ARP 1 inch stainless 6 point bolts, they won't rust and you can get a open end wrench on them if you need to. I use Felpro 1470 gaskets as they fit my headers the best. Regardless of which gaskets you choose make sure your header flanges are flat and true as welding tends to warp them, especially in the area of the center two pipes. The flatter the flanges are the better chance you'll have of them sealing well.
There is no need to apologize for asking questions, pay no attention to that other exclusionary thread.
Old Oct 22, 2012 | 12:26 PM
lt1-xjs's Avatar
Also keep in mind the tightening between heat cycles. That's the key. You may have to tweak them 4 or 5 times.
Old Oct 22, 2012 | 03:44 PM
Default thank you
thank you to everyone for ur time it is greatly appriciated.
Old Oct 22, 2012 | 03:51 PM
OwieVT's Avatar
I have the Percy's soft aluminum gaskets and they work great. I used the bolts that came with mid Pacesetter mids. I put the headers on, retightened them after one heat cycle and two years later I have not touched them again.
