Beehive springs Strikes again.(edit) Now called : Engine rebuilt 2013 .
Old 02-18-2013, 11:48 AM
  #121
BALLSS's Avatar
Originally Posted by mpcv2000
This is where I'm at right now .
I may have some down time again because the bolts ( studs ) for the pressure plate won't work.
what clutch you using?
single disc LT1 "pull" or?
if single pull type ARP makes PP bolts
http://arp-bolts.com/images/releases/134-2202.pdf
Old 02-18-2013, 12:42 PM
  #122
mpcv2000's Avatar
Never mind the studs on the pictures they are not the right one and the CenterForce clutch kit came with the ARP bolts you suggested me but it doesn't work so today I'm trying to figure out something .
Here's my clutch :
Old 02-18-2013, 01:54 PM
  #123
BALLSS's Avatar
Here's my clutch :
that "looks" like a LT1 FW, aluminum with insert?....weird the CF clutch does not bolt up to it
do the PP holes not line up with the holes on FW?
Old 02-18-2013, 01:59 PM
  #124
mpcv2000's Avatar
I had the Fidenza Flywheel modified with steel inserts and looks like the ARP bolts are too short so I may use the one you see on the pictures.
I'll be working on this later on today. ( I'm at work right now ) .
Old 02-18-2013, 02:19 PM
  #125
BALLSS's Avatar
I don't have any experience with Fidenza FW or ones with inserts but from the pic it looks like the insert sits higher than the FW that the PP bolts to....which in itself I would think is a problem as the PP now would sit to high.
I guess you could force the PP down by drawing the bolts tight..don't see that as right though as it would deform PP. I also know if TQ is more than 22 ft lbs on PP bolts there will be disengagement issues.
You look to know your way around a wrench (you garage is amazing) and "mods" do require some fab/engineering.
I know the LT 1 PP bolts are "unique" and fortunately ARP now makes them.
Good luck and post what your solution is.
Old 02-18-2013, 02:34 PM
  #126
mpcv2000's Avatar
Good infos.
I'll be careful tonight and pay attention at what you said.
Old 02-18-2013, 09:16 PM
  #127
mpcv2000's Avatar
Feb 18 2013 updates :
Finally I did use the studs I had before and did not touch the ARP one , they were too short.
Here's the updates
Ready to lower the car on the motor.
Easiest thing ever.
Motor out from under is the way to go.
So far looks like start up is coming very fast.
Old 02-20-2013, 05:19 AM
  #128
95mysticta's Avatar
Lookin good martin!
Old 02-20-2013, 06:32 AM
  #129
mpcv2000's Avatar
I've been working on the car last night.
No pictures taken because all I'm doing is plugging stuff , installing hoses etc.
Tonight I should be able to fill all fluids and start installing the exhaust for 1st start up Thursday evening .
Old 02-20-2013, 08:19 AM
  #130
wrd1972's Avatar
What are folks thoughts on whether those weights on the Centerforce pressure plate really provide any benefit. I am skeptic.
Old 02-20-2013, 08:50 AM
  #131
mpcv2000's Avatar
I have no idea if it is good or not yet.
The only test I did was put the car in gear , depress the clutch to make sure it disengage and the rear end can spin freely while in gear and it does so we'll see.
The clutch pedal feels different then my SPEC III tho.
Old 02-20-2013, 01:04 PM
  #132
draggin97s10's Avatar
I would kill to have your garage..literally.
Old 02-20-2013, 01:58 PM
  #133
SoxXpupPeT's Avatar
Your not the only one! Damn... Thats all can be said. It looks cleaner then an operating room! Car looks AMAZING!
Old 02-20-2013, 02:01 PM
  #134
mpcv2000's Avatar
It is kind of.
Old 02-23-2013, 07:30 PM
  #135
mpcv2000's Avatar
It's back to life :
I haven't done any editing so it is long a little + when I zoom somehow we lose the sound.
I was trying to catch the motor rocking the whole car.
In the first part of the video never mind about the smoke in the engine bay , this was really the 1st start up , 2nd part the idle is lower ( around 850 RPM ) and it sounds way better and stopped smoking.
Old 02-23-2013, 11:21 PM
  #136
SoxXpupPeT's Avatar
Sounds Awesome! is it me or does your valve train need to be adjusted? Im surprised at how quiet and tame the exhaust sounds out the back. What muffler is on that? Congrats again for getting it back up and running!
Old 02-24-2013, 05:13 AM
  #137
mpcv2000's Avatar
The camera did catch some valve train noise ( worst then it sounds really ) but it became quieter a few seconds after.
The machinist told me he took the lifters apart to clean them so maybe they were not completely recharged.
2nd part of the video valve train noise is completely gone.
As of exhaust all I have is a Magnaflow muffler right before it is a small resonator that's about it.
Old 02-24-2013, 10:20 AM
  #138
BALLSS's Avatar
especially on a "pull" clutch.
CF does this on their clutches....I would think the centrifical force pulls them to the outside...and that is supposed to increase clamp load.
from CF website:
https://www.centerforce.com/technolo...rforce-weights
Feels so good to be on this side of the build and having the motor fire right up
great jop OP
Old 02-24-2013, 10:40 AM
  #139
mpcv2000's Avatar
After a few test ( on the lift ) with the motor running the clutch works perfectly but the pedal does sits lower then before , not sure if it is normal .
It is not as stiff as my SPEC III .
Old 02-24-2013, 11:48 AM
  #140
SoxXpupPeT's Avatar
Sounds awesome. pretty tame at idle and ferocious at revs
Quick Reply: Beehive springs Strikes again.(edit) Now called : Engine rebuilt 2013 .
