Spark plug recommendation
Old Jun 5, 2013 | 07:40 AM
kgkern01's Avatar
Default Spark plug recommendation
I just finished assembling my 13.5:1 385, with EB ported stock castings and custom LE cam 24x/25x, running on E85. What spark plug and gap should I run with this setup? Thanks!
Old Jun 5, 2013 | 10:38 AM
BMX Dad's Avatar
I was running NGK Iridium IX Spark Plugs NGK-7164
My tuner said:
If your looking for max life span that is the best plug
If your looking for max power that is the worst plug
If your looking for normal plug life and max power use the NGK copper TR6 - 4177
Old Jun 5, 2013 | 11:16 AM
BOLO's Avatar
NGK TR6(4177) gapped@ .035"-.038"
Old Jun 5, 2013 | 07:03 PM
Wicked94Z's Avatar
Br7ef would be a good start. You don't want an extended tip plug or a hot plug with E85. I'd run the gap around .024"
Old Jun 5, 2013 | 07:14 PM
Wicked94Z's Avatar
I ended up with an Autolite 3911 (5/8" gasket seat .750 reach) which has slightly projected tip, ("power" tip) but nothing like say a 3923 plug. It's roughly equivalent to an NGK -8 plug. It was worth some mph when I switched from the NGK -7s.
Old Jun 5, 2013 | 07:42 PM
Ed Wright's Avatar
9-Second Club
Why in the world would anybody use a .024" plug gap???
Old Jun 6, 2013 | 02:26 AM
Wicked94Z's Avatar
What plug gaps do you use with E85 Ed?
Don't see too many guys running 6-series boxes (I'm assuming the OP is running an equivalent) on alcohol... Why not start small and increase the gap if there are gains? I forgot to mention in my prior post, I closed the gap from ~.030" to .024" when changing from -7 to -8 plugs and saw a consistent 1/4 to 1/2 mph gain, and zero change dropping to .022" or .018" gaps.
Old Jun 6, 2013 | 06:12 AM
Ed Wright's Avatar
9-Second Club
I never ran gaps that close on straight methanol. Did you A-B-A test that at the track, same day within a short time period?
Old Jun 6, 2013 | 06:18 AM
kgkern01's Avatar
I'll pickup a set of the Br7ef 's today, I don't have an ignition box yet, but I do an on getting one soon. Until then I'll try .030" gap for now.
