Crankcase Breather
Picking up a SC'd Z28 this weekend and under boost conditions it's blowing oil out the tail pipes. I am buying it under the assumption the motor is dying, however, I also wonder, since it's not present at idles an non-boost cruising, if I may be able to get some sort of breather setup installed in case it's the crankcase getting boosted causing it.
On my older 3800 cars the oil fill was on the valve cover so it was super easy to install one and it worked well. Can I just do the same here with the LT1?
I also ended up using 2 valve covers that had the fill for two breathers; is that an option here?
Thanks for any insight!
Brian
The guy that bought it is actually really nice and I feel terrible that the prior owner completely screwed him.
So crankcase breather - any other thoughts? Just want to go after the simple things in case it is a simple fix. I know it has mismatched everything and that it wasn't well thought out, and this is not likely to fix anything, but still, worth a shot.
So outside of tapping the intake is there another way?
Brian
