3.42 vs 4.10 gears
I just checked the gears in my (motorless) '97 z28 and found out it really does have 4.10 gears. However, my Firebird has 3.42 gears so I, of course, plan to swap 'em. I hear the obvious statements that 4.10s are much quicker through the 1/4 mile but have a lower top speed and worse fuel economy. But I want to hear your experience with them with good detail.
4.10's are great gears for a 6-speed, but I'd be hesitant to put them in a car that is seeing slicks and track times with an otherwise stock rearend setup. Not to say it hasn't been done, but it's inviting problems in your near future.
from a "gearing" standpoint the 94-97 T56 with 4:10 is a great combo. On the street it's a 4 speed. I don't shift into 6th unless going OVER 65mph. At 80mph I tach about 19xxrpm with a 27" tire.
I run a 26" MT ET Street at the track
I picked up quite a bit in the 1/4 going from 3.42 to 4.10 and loved how easy it was to drive in traffic. They are much weaker though. I broke 2 4.10s and the car never saw anything stickier than Nitto 555R drag radials. Snapped teeth right off. It's been a while, but if I recall, I was also crossing the line at 108 MPH which put me over 6000 RPMs in 4th. (I shifted at 6200).
The cars are both so much more pleasant to drive with the 4.10's. The double overdrive makes them perfectly useable...unlike 4 series gears in an older/non-overdriven car.
I have broken one set of 7.5" - 4.10's in the SS with street tries, but they lasted about ten thousand hard driven miles....and they were loud when I got the car so I suspect they were not set up correctly to begin with. That car now has a 12 bolt still with 4.10's.
Either keep your 3.42's in case you need to swap back for any reason.....or sell them to someone with an A4 car. They are great with the 4L60E especially if someone has the 2.73's originally.
