WANTED: Hypertech III 30027
Old Sep 30, 2013 | 07:51 AM
ckyconan2003's Avatar
Default WANTED: Hypertech III 30027
It's been awhile since I've posted but I've got my dads 30th SS and I'm fixing everything he doesnt have time to.
I'm looking for a programmer to ensure the ECU is tuned for 93 octane and maybe get a little more performance.
Just thought I'd put a feeler out for one of these things.
Thanks,
Old Sep 30, 2013 | 08:24 AM
RamAir95TA's Avatar
Ew, gross. Don't waste your money, ESPECIALLY for the "power tuning." Many people have reported an actual LOSS with the tuning.
What you want is a mail-order tune. Try www.pcmforless.com, Ed Wright, etc.
Old Sep 30, 2013 | 10:38 AM
jrwilliams95z28's Avatar
I have one I'm not using but yah the power tuning is awful I went to tuner cats it's way better
Old Sep 30, 2013 | 11:04 AM
shbox's Avatar
If you want performance, you don't want the Hypertech.
Old Sep 30, 2013 | 12:03 PM
Shbox, you're in LR? I live in Bryant.
I'd use PCMforless but have no way of installing the tune. Again, this is a bone stock SS 30th car and my main concern is ensuring it's tuned for 93-octane.
Old Sep 30, 2013 | 12:15 PM
kinglt-1's Avatar
Its simple...you send the mail order tuner the pcm, the tuner of choice tunes it and ships the pcm back to you.
Old Sep 30, 2013 | 12:20 PM
lol, do they send me a core ECM in the meantime so I can drive the car? hah
Old Sep 30, 2013 | 12:24 PM
kinglt-1's Avatar
Years ago Bryan would send you out a tuned PCM in exchange for yours, but I dont think it works that way anymore. Check the website or call.
Old Sep 30, 2013 | 01:45 PM
bufmatmuslepants's Avatar
You realize these are tuned for 93 from the factory right?
Old Sep 30, 2013 | 02:30 PM
That's what I originally thought but wanted to make sure. Did I leave that out of my original post?
Thanks guys,
Old Sep 30, 2013 | 03:21 PM
That's exactly what I wanted to confirm. Did I leave that out of original post?
Old Sep 30, 2013 | 04:20 PM
fruitsalad's Avatar
Someone already mentioned this but stay well, well away from the Hypertechs. They will not only hurt performance but also cause detonation in some cases.
Old Sep 30, 2013 | 08:31 PM
warriorcustoms's Avatar
I sent you Moe's info!!! Hes pretty close to Frisco Tx thats in your sig.
Old Oct 1, 2013 | 09:45 PM
jewbacca's Avatar
Another option is to buy an ALDL cable, and load the tune yourself. It's a great option as it gives you a way to datalog your car to get things dialed in.
Old Oct 1, 2013 | 10:15 PM
Puck's Avatar
Hypertech "Power Tune" is worthless, and never in a million years would I pay anywhere near retail for one. They are neat to change shift points, raise the rev limit, adjust speedo, or remove top speed limiter in a pinch though.
Main problem are that they are WAY overpriced, and get locked to one VIN at a time. If you can snag one cheap/free they are a useful tool to have - just a little handheld that you can stick in the glovebox at the track to play with shift points and rev limits instead of having to bring out the laptop, power cord/inverter, and cables. The TA I picked up came with one, and although I still plan to get the cable to datalog and do real tunes like I do with my 93, it was kind of neat to play with.
I've never heard of one causing detonation in an LT1. The timing curves they use are so mild, and our engines are already extremely resistant to detonation I have a hard time seeing one cause any unless they got a bad batch of gas.
Old Oct 1, 2013 | 10:21 PM
fruitsalad's Avatar
To clarify my post the deto was on an LS1.
Old Oct 2, 2013 | 08:07 AM
I need to change that, I'm in the LR area now.
The car is running much smoother after a tank of V-Power, some Lucas Oil fuel system cleaner, and Mobil 1 EP. However, now it's making a weird noise at idle. Coming from the back of the engine/bellhousing area. Car is running fine it just makes this weird honking-whistle noise when I'm at idle for about 7seconds on then 7seconds off. Seems to be connected to the throttle position. Never heard this sound before nor have I ever heard someone mention this before.
