Coolant leak / system pressure...
I had her park on the street that night to not stain the driveway.
Long story short, ots a coolant leak. I looked underneath and saw the water pump leaking from one side where it meets tje block, and also from the meziere electric pump where it seals on the front. I put this meziere unit on about 2 yrs ago, have had zero issues.
So I go to take the radiator cap off and POP, the thing all but flew off the radiator and was obviously under some pressure. Keep in mind the car was cold at this point and had not been ran all day.
What could that pressure be from? Kinda weird the the pump spring a leak in two different areas that quick. The pressure concerns me. I refilled the coolant to see how much ot had lost, and it only took a quart or less.
I'll have more time for diag tommorow.
Anyone know why the cap would have had so much pressure?
I really sealed up the water pump good when I installed the meziere 2 years ago...
I'm gonna do the chemical test to make sure is isn't exhaust gas, then go ahead and re-seal the W.P. and go from there.
Thanks for the help guys.
-Matt
Just spent almost $600 yesterday on our 300ZX to pay registration and stuff to get it back on the road.
Now this, and on top of that I need to build a motor for my Trans Am, but now the funds have to go to the Camaro.
Guess its time for heads/cam. Freight out here to Hawaii sucks ***. And I'm gonna just grab a whole different motor in case there's a cracked wall in the cylinder or something. Picking up a used 80k miles motor from a friend tomorrow for cheap.
Hopefully the bottom end won't need much work.
On a side note,
I picked up a used longblock with 85k on it for $200.
So I'm gonna do a light rebuild on the shortblock and go with an LE1 set up.
Will Ion be able to do a good Daily driver tune on it? Hope so.
