lt1 ignition issue
Old May 12, 2004 | 03:21 PM
nspr8td lt1's Avatar
Default lt1 ignition issue
car has brand new spark plugs, opti, plug wires and water pump have 12k miles. i get a stutter now and then and sometimes the car will shut down in traffic. im praying it isnt the opti and i dont think it is. any thoughts???
Old May 12, 2004 | 03:31 PM
Vendetta's Avatar
Check your O2s. Is your car stock?
Old May 12, 2004 | 03:39 PM
car has moroso cai, lt4 km, ngk tr6 plugs, no cats, cutout, nx 150 shot.
Old May 12, 2004 | 08:30 PM
any other thoughts?
Old May 12, 2004 | 08:43 PM
Vendetta's Avatar
hmm... do you know if it's missing at all? Or just shutting down? How is it throughout the powerband... is it just down low?
Old May 12, 2004 | 09:11 PM
only on idle or part throttle, never at wide open.
Old May 13, 2004 | 01:16 AM
96SCTA's Avatar
i dont think it is your opti. If it was it would not be fine durring wot. I am thinking you have some sort of intake leak. Do you have access to a scanner or any sort.
When my o2s were bad the car would act up down low but run fine at wot. So that is also a possibility.
Old May 13, 2004 | 02:02 AM
Vendetta's Avatar
I'd bet that it's either a bad O2 or a vacuum leak.
Old May 13, 2004 | 11:37 AM
i found a crack in my intake elbow where my nitrous nozzle is inserted. looks like its time for a trick flow metal elbow.
Old May 14, 2004 | 09:28 PM
dhdenney's Avatar
I had a leak in my elbow once and that was causing some stutter. What year is this car? If you have no cats and it has OBDII electronics then your rear sensors may be screwing you up.
Old May 14, 2004 | 10:18 PM
yea its a 96 0bdII i fixed the leak but i still get a small stutter every now and then, im gonna check the o2's.
Old May 15, 2004 | 09:31 AM
dhdenney's Avatar
I would pick up some O2 sims for the rear then. I've never fooled with OBD2 but if they make O2 sims for the rear sensors and not for the front (at least I've never seen them), then those rear ones must do something.
Old May 15, 2004 | 03:27 PM
93PATAJustin's Avatar
hey i had a problem very similar to that in my 93. The ignition module was goin out and would cause the car to stall every once in a while. The shop couldnt diagnose it, cause it only threw a code when it decided to act up. The part is only like 80 bucks from the dealer....might be the problem?
Old May 15, 2004 | 04:49 PM
thanks for all help guys.
