Barely 1,000 miles, knocking sound.
Motor is brandy new. 355, all forged lower internals, cc306 cam, new lifters and valvetrain components, all new, high volume oil pump.
Just noticed today it started making this sound today.
A few points, normally since the new motor, idle is around 60 psi oil pressure, but now since the sound developed, its around 40 psi.
It seems to only do it hot. No noticeable lack of power in any range. Can hear the noise most when decelerating or accelerating.
Oil on the dipstick is still clear, no metal flecks.
With the hood open, the sound seems to come from the top of the motor.
The noise increases in frequency with the revs of the motor.
Thats about all the information I have. The highest revs the motor has seen is about 6400 but that was a good while before this noise developed.
Any pointers or thoughts would be greatly appreciated.
the oil pressure drop is concerning though....that points to bearing wear...and noise is not good. you don't see metal flakes in oil, good...cut open oil filter to see better wtf may be in there...if metal flakes..you need to pull motor and address bearings before severe damage
Does the oil pressure drop when you rev it? Try this, put it in 3rd at like 40mph and give it the go go pedal. But stay in third, what happens to the oil pressure?
Seems to be more of a chirp, and less of a ting ting ting. Its rather humid and wet in the Northeast today so all signs are pointing at something in the accesory drive. I let it cool and started it up and didnt make a peep til it got warm. It just sounded so high pitched and was so short in duration. I'm gunna analyze further and report back.
HV oil pump is paired with a Canton 6 quart (almost 7 in actuality) pan with baffles. Not running a stock pan. Car at idle runs about 60-70 psi cold and apparently around 40 warm, which is mildly suspicious since i never noticed it before. When warm, any gas instantly brings oil up to around 60 psi and increases to around 80 at near redline.
Should also mention I was able to drive the car home nary a problem. The noise seemed to come and go as best I could hear considering its LTs through straight pipe and out a GMMG catback.
1- locate with stethoscope
2- pull plug wires one at a time
3- open oil filter for metal
4- disassemble engine
A stupid hobo fake stethoscope is <$10
Pull the plug wire cost nothing
cut open oil filter = cost of oil change
dissemble engine - better now than let the engine eat itself
This guess what my noise is has become more than a stupid exercise here. If your too lazy to get off your keyboard and look u dont deserve an answer.
The oil pump is a positive displacement pump and output is linear with rpm until it reaches the bypass limit and stays at that max press setting. So u at least have a bad oil pump and the oil pan needs to come off anyways.
Or like this?
The HV oilpump was a bad choice, if you are fortunate enough to find an external cause for this problem GREAT but always keep an eye on the oil pressure because you are likely to wipe out the drive gear. If the engine comes out put a standard volume pump in it.
Anyone who told you it needed a HV to support the extra HP is an idiot, that pump is more likely to cause damage than fend off any. Pan capacity helps avoid sucking the pan dry but does not address cavitation, filling the valvecovers, wearing out the drive gear.
A few really high HP builds might make use of one with really loose bearing clearances but on a normal modest street build it ONLY offers problems.
FWIW I did a good bit of googling and you tubing before posting to see if I could find a similar sound but, there really isn't anything like it. That is why I presented as many facts that I knew to get the best guess from others.
It's still getting put up on a lift, examination of the oil filter yada yada, just as a cursory inspection.
TBD on the "bad" pump. But as a note, through the power band, psi is linear up tip about 80-90.
Thanks for those videos. The sound isnt similar to either, and it doesn't sound anything like rod knock.
On another note I have read quite a few post on here where guys get a little upset because they do not like or feel the OPs know what they are doing or ask the right questions. Guess what guys? That is why they are here.
If you don't like someone's question simple don't answer. It belittles everyone hearing you **** and moan because you are so superior. There should be no dumb questions here. Sometimes posters are ignorant to facts and over their heads but to demean doesn't help.
@Jr. Samples. I agree. Sure, I should of had a toolset with me and all but I honestly felt the best way to get some ideas the quickest was to just ask. I apologize for being less versed on these cars than others. But I learn more every day. I could see though, where the reaction I got from asking such a question would have turned other possible OP's away from even asking a question in the first place. A forum is a place to discuss something. If everyone knew everything and was mechanically and technically superior in all respects, then there would be no point in even having a forum.
