Question: LT1 MAP sensor 1, 2 or 3 bar?
And have fun..
http://www.camaroz28.com/forums/comp...uction-560089/
Sounds atrocious lol
And have fun..
BUT, I am sure the old timer LT1 guys will come in spouting how it worked fine back in the day and no need to change anything etc etc.
My Impala had the Turbo Technoologies kit on it for many years running 36 lb injectors and the stock MAP sensor.
Since I built that car there have been a few guys rework the stock PCM tunes/software to use a 2 bar MAP, and they likely work fine also. You can run Speed Density (MAFless) that way which does have advantages.
So check with your tuner, and Moe and see what they suggest.
But you can't just plug a 2-bar MAP into the car and have it run right.
Bob
Bob
