SLP lid
Edit: i have a lid if you're looking for one. I don't have the radiator cover that it slips into though.
sunoco wide? hmmm.. knew there was a taller one but not a wider one. got any pics of this to share? What did you have to trim to make it work? I've been looking at the sunoco hood for a while and its also on my list of things coming... just want to know how much bigger this wide one is from the 'normal'.
It's not actually wider, it's just taller. On the underside of the hood near the front, they remove some of the bracing and cover it so it's not just unfinished. If you call and talk to Jeanie ask her to do one like Butch and Chris. It's been a few years since they did mine. The only trimming that needs to be done is on the radiator cover/lower air box to fit the contour of the core support. The LS has a flat support where ours has a bit of a high spot. Everything else is bolt on.
