Another Water Pump Thread...
Old Jul 8, 2015 | 10:17 PM
  #61
hrcslam's Avatar
Default Another Water Pump Thread...
A stock pump is a fixed impeller and constant displacement (for teh sake of agruement here), so making something that works at idle may be overkill or unneeded at WOT.
Granted I do not take highways at ~120mph but, still curious on if cases ACTUALLY exist where an EWP car had to switch to MWP.
The answer is yes, but it's dependant on engine output, ambient conditions, run time, and other supporting cooling system mods.
So for me, road racing with only a 160 stat and retuned efans and 100+ ambient conditions, I'll reach the limit of the EWP sooner than if I had a dual core radiator installed and 85 degree ambient conditions.
If someone with an EWP was to measure the pressure of the coolant just after the impeller I can tell you what it's actually flowing as installed. If I had an EWP I'd measure this my self.
  #62
hrcslam's Avatar
Originally Posted by VoyagerCamaro
Well after hours of cleaning and scrubbing with rags, she's clean! As I can get it at least lulz. All that's left is remove the crank hub, then opti and I'll be putting on the new seals. Went ahead and put a new water temp sensor on my water pump, cleaned it as well.
The opti is visible again!
Scrapped off the old gross baked on gaskets
All clean
Cleaned the WP, installed new temp sensor with some Teflon sealer. Not to shabby for practically 160k mile car.
Looking good!
Old Jul 9, 2015 | 02:36 AM
  #63
VoyagerCamaro's Avatar
Originally Posted by hrcslam
Looking good!
Hopefully it'll stay looking that way. I'm currently at work, I need to buy the right sized sharpie for tomorrow when I do the seal. I'm pretty sure it's just leaking from the WP drive, but I have to take the opti off anyway so should I go ahead and put on all the seals and o rings while everything is off??
Old Jul 9, 2015 | 03:54 AM
  #64
hrcslam's Avatar
I would replace all the seals you have access to. I used a 10mm deep well socket IIRC to install the water pump seal.
Old Jul 9, 2015 | 10:25 AM
  #65
BALLSS's Avatar
some use the coupler to slide the seal on....or the right size long socket
Old Jul 9, 2015 | 11:13 AM
  #66
sweetbmxrider's Avatar
Seriously? From the guy who started the entire argument trolling the other thread slinging false claims about EWPs? Everything I said was factual. You haven't proven me wrong.
Come here to Arizona, let's race. Leave it on the track.
No, no you did not. You posted your opinions and hearsay. You claimed to have facts, I asked for them, you made fun of me like a preschooler. You have yet to prove a thing that I called you out on. You get stuck on these random tidbits and have forgotten entirely why the discussion was actually brought up, aside from ewp = win. I guess you got butt hurt on that? Not sure.
I'm not driving halfway across the country because someone calls me out. I have more important things to do, like call AAA. I am flattered though!
BMX is parting out his car for "business expansion" guess he knew one day a car with a MWP would out run his.
I'm not sure who you are or what you do but if you want to scrape your pennies together, I can cut you a deal on my motor. I'm sure there are lots of cars that would bitch slap mine with a mwp. I don't see any setups on here that would though. Maybe some of the b body guys are running mechanicals and hauling ****** ***? I do love guys like you that talk **** with another guy's car. How does that feel?
Old Jul 9, 2015 | 11:29 AM
  #67
Bruh, I'm scraping pennies together to get a used water pump I wish I could afford to have a motor like yours not talking **** on your car, just trolling as usual
Old Jul 9, 2015 | 02:40 PM
  #68
hrcslam's Avatar
You've got things all backwords, it's you that's conjuring opinion as fact. What I provided was factual.
Have you proven me wrong? You can't. Wonder why?
Old Jul 9, 2015 | 02:57 PM
  #69
HRC, I'm having trouble getting the crank hub off, I removed the 3, 5/8ths bolts and still can't get the hub off that triangular looking thing. Bleh. Any tips?
Old Jul 9, 2015 | 03:05 PM
  #70
hrcslam's Avatar
Mine pulls right off. It's a tight fit, but isn't pressed on. Try some lube on the hub, you want to get it between the hub and the pulley. The triangle thing is the hub, the pulley bolts to it with the 3 bolts you pulled out. The hub is pressed on and the secured with a center bolt. To get the hub of you'll need to remove that centry bolt (5/8 IIRC) then use a puller.
Old Jul 9, 2015 | 03:45 PM
  #71
Most people have told me the pulley falls right off, mine sure hasn't! LOL, I usually just rent a puller but I though I'd try it this way. I gotta get this thing back on the road. Driving this 1982 carbureted 4 cylinder Toyota hilux back&forth to work is not cutting anymore lmao!
Old Jul 10, 2015 | 10:34 AM
  #72
My bad
You are delusional. I suggest you reread the thread but you won't, you have an attitude that won't let you be wrong. Continue spewing bullshit and hypothetical theories, its only the internet
Old Jul 10, 2015 | 02:16 PM
  #73
SS RRR's Avatar
Village Troll
My Continue spewing bullshit and hypothetical theories, its only the internet
You continue being man-crush's angry dingleberry.
Old Jul 10, 2015 | 03:19 PM
  #74
hrcslam's Avatar
My bad You are delusional. I suggest you reread the thread but you won't, you have an attitude that won't let you be wrong. Continue spewing bullshit and hypothetical theories, its only the internet
Still got things backwords.
Old Jul 10, 2015 | 09:33 PM
  #75
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Maybe it's just me, but that water pump driveshaft seal is clearly not installed correctly. It looks like it was pushed on by hand until some resistance was met, at which point the installation was deemed complete and everyone went to the bar. In defense of the installer, I will say that beer is effing delicious.
Old Jul 10, 2015 | 11:32 PM
  #76
The pic was taken after I had popped the seal out, it got a little fucked up when I was taking it out. And no beer for me, just 17. Don't think id be able to concentrate with some beer in me lol... Haven't had time to work on it today bleh Only time I'll have any chance to work on it this week will be Wednesday and Thursday, I'll post some pics with updates. Wish voyager and I luck :
Old Jul 12, 2015 | 12:44 AM
  #77
Well things were going smooth, took the timing cover off... Timing chain has at LEAST 3/8" of play in it it is wore out big time after 157k miles.... Bleh I'm very upset to find this. Guess that's what I have to order tomorrow morning, when I was oh so close to being able to buy some sway bars... Meh
Anyone know best replacement chain that isn't too expensive?
Old Jul 12, 2015 | 01:35 AM
  #78
hrcslam's Avatar
Stock replacement will be your best bet. Don't forget sprockets too (get the right one for your year, they differ between vented and non-vented optis). LT1's do have a little more chain slack than I expected though.
Old Jul 12, 2015 | 10:52 AM
  #79
I just bought a cloyes one at oreilys. It's for a 95, it'll be here at 2:00 o'clock. I have the receipt in case it's wrong, however the P/N was different between the 93 than the 95 so hope it's right how can you tell the difference between a vented design camshaft gear and non vented?
Old Jul 12, 2015 | 11:37 AM
  #80
SS RRR's Avatar
Village Troll
It's the way the optis are driven. Look about half way down this page:
https://www.nookandtranny.com/Info_LT1.html
