lt1 EWP problems
Which pump are you running? A 15 amp buss fuse is probably for a pump that flows less gpm and has less draw.The install kit i have is the same as the Painless kit just summits brand. I wired it by the diagram it came with. Utilizing the 30amp breaker, the relay and a 30amp buss fuse that came with the pump.
You just need a relay & inline "weather pac" blade fuse. 15 amp
You likely have a generic EL. Fuel Pump type fuse/relay kit which comes with both 15 amp fuse (although a BS barrel fuse) and a 30A circuit breaker for multiple applications.
My Painless Wiring kit was like that 17 years ago when I wired mine. I have the Meziere
Just use the relay & Blade 15a fuse
The Meziere pump only has one inline blade fuse. And like you, I am running main power from PS red terminal through a relay and switched ignition from DS junction box. I wired it once and off I went, zero issues.
