Is it possible for an LT1 to run too cold?
You do NOT need to have your fans and jive reprogrammed, the thermostat alone will change the engine's operating temperature. Whoever told you that is just jiving.
Now the myth you have heard about it affecting engine life...?....this "myth" my friend has a grain of truth to it and it runs all the way back to the factory,
you see the factory tested and researched the engine to operate at 195 degrees(don't qoute me)this was the temperature they tested the oil to be warmed up to, to provide it's best lubrication AND protection.
So in essence cooling that temperature too far down takes that "factory" tested and researched value out of the equation and in to your own little world of testing and research with probably nowhere near the factory budget and experience. But what is true is the performace advantage of cooling the operating temperature and the AIR the engine intakes down, so you have to look at it from a balanced point. You want to cool off a little for the performance advantage but not too much to wear the motor.
What did I do?? with my engine at 120 in NYC during the winter months??
I took the 160 back out and in it's place went a 180 which I kept in her for 2 years this kept me cooler than stock at 160-180. Then I moved to Florida. And on hot summer days it was hitting 185-190 and never ran below 180.
Lucky for me I never threw out the 160.
The 160 went back in. I run at a cool 140-150. ALWAYS. The thing never budges. And I'm comfortable with the added insurance on HOT HOT days.
Can I recommend the 160 in cold weather? No way no how.
Is it just a myth? I seriously don't think so. Running 120 on cold days is too far from what GM intended and tested.
If your in hot weather go for the 160.
If you get some cold do the 180.
Just .02 cents worth, good luck and play hard.
. Remember that the thermostat will close until the coolant reaches 160 degrees. I don't think its possible to go below that once the Tstat has opened. Which sensor were you reading when you saw 120 degrees? I live in Jersey, we get mostly the same cold as in NY and I have never gone below 167-8 once the tstat initially opened.Rich
