Max compression ratio on 93?
Old May 24, 2016 | 07:57 PM
ElkySS's Avatar
Default Max compression ratio on 93?
I'm trying to plan my next build. I'm currently running about 11.5:1 on 93, I know some guys run some crazy high compression ratios on pump gas and I'm curious what the safe limit is. It will be N/A for now and get a shot of Nitrous down the road. I cant see it being much over a 250 shot though.
Old May 24, 2016 | 08:14 PM
HCI2000SS's Avatar
What kind of motor?
Old May 24, 2016 | 09:10 PM
VoyagerCamaro's Avatar
On my old car, i had 11:7:1 compression with no issues. But I made sure and always kept very, very good quality gasoline (Shell Nitro 93 octane) I was running speed pro pistons (I'll have to check the part number), 0.26 head gaskets, CC503 cam, 160* thermostat, stock heads and many many more mods.
Old May 24, 2016 | 10:45 PM
ElkySS's Avatar
I've heard of guys running around 12.5:1. I'm wondering how feesable that is. I'd like to run about 12:1 but I don't wanna push the envelope too much
Old May 25, 2016 | 04:26 AM
hrcslam's Avatar
I'm at 11.8:1 on 91 octane in the Phoenix heat. No issues. The reverse cooling works as advertised.
But, you HAVE to take into account intake valve closing event timing too.
What cam do you plan on using?
Old May 25, 2016 | 05:20 AM
ElkySS's Avatar
Not sure yet. I'll probably let my head porter decide
Old May 25, 2016 | 07:36 AM
bowtienut's Avatar
I think it all depends on how you plan to use the car.
For drag racing and general driving where the motor doesn't already have a lot of heat in it when you're at full power, 12:1 is manageable on 93 octane. I ran 12.0:1 for 6 years on my heads/cam motor with never a detonation issue. BUT.....for open track sessions where it got very hot, I always mixed half 110 octane race gas.
For the new 383 build, I'll have 11.5:1, a 238 dur SR cam, and will run strictly 93 pump gas, even on the roadcourse.
Old May 25, 2016 | 03:26 PM
KW Baraka's Avatar
I'm running about 12.5:1.....but then, I have a 246* solid roller cam.
I've never had an issue with heat, but I only put about 1500 miles a year on the car. So.....there's that.
Make sure your builder cams the engine appropriately and optimizes your quench (about .030" to .035") and you should make out OK.
Originally Posted by bowtienut
......12:1 is manageable on 93 octane.......For the new 383 build, I'll have 11.5:1, a 238 dur SR cam, and will run strictly 93 pump gas, even on the roadcourse.
Yep......looks good !!!
KW
