good cam for 383 stroker
Old May 4, 2017 | 12:15 AM
Cj Justice's Avatar
Default good cam for 383 stroker
i have a 383 stroker lt1 with advanced induction 200cc heads and full bolt ons. the cam was destroyed with previous stock shortblock. so im now having to get a new cam old one was a advance induction 228/234 .612/.612 lift 108 lsa iirc. what cam would be great for my set up i want a huge cam thanks yall
Old May 4, 2017 | 01:39 AM
KW Baraka's Avatar
Originally Posted by Cj Justice
......... i want a huge cam thanks yall
You can get a cam from Comp Cams that would be 264*/268* with about .661" lift on the intake and exhaust and your choice of LSA.
It would probably perform worse than ****.....but at least it'd be "a huge cam".
Jus' sayin'.....
KW
Old May 4, 2017 | 05:57 AM
bufmatmuslepants's Avatar
Id call AI or Lloyd Elliot and tell them what you want and have them spec you out one that meets your needs.
Old May 4, 2017 | 09:14 AM
bowtienut's Avatar
^^^ What he said.
I ran your old cam in my 350 with those same heads.
If your stroker has a fairly high CR, you might want a bit more duration this time. What is the CR?
Old May 4, 2017 | 01:35 PM
hrcslam's Avatar
Billet!!!
Old May 4, 2017 | 01:46 PM
bowtienut's Avatar
Originally Posted by hrcslam
Billet!!!
...and just why would you say that?
. JK....I've read your bad news If you can defy odds like that, maybe you SHOULD play the lottery!
Old May 4, 2017 | 01:48 PM
hrcslam's Avatar
Right?! It's ridiculous.
OP. We really need to know goals and engine specs to help you out.
Old May 4, 2017 | 02:14 PM
SS RRR's Avatar
Village Troll
https://ls1tech.com/forums/lt1-lt4-m...l#post19612100
Old May 18, 2017 | 06:37 PM
Wheel Stander's Avatar
What transmission and gear ratio are you using? Do you know your compression ratio? What size valves are you using? It's not as simple as you're trying to make it. My suggestion ... contact Lloyd Elliott ... he knows as much as anyone when it comes to the Gen II LT1 motors.
Old May 18, 2017 | 08:39 PM
LINE'EM UP's Avatar
I'd contact AI, you already have heads ported by them so I'd guess they would know what cam will perform with those heads in that application
Old May 19, 2017 | 04:18 AM
96lt1m6's Avatar
What is wrong with getting the same cam from AI?
Especially if that cam was a combination with the heads you have. Not to mention bigger is not always better...
Old May 19, 2017 | 07:39 AM
bowtienut's Avatar
My understanding is that his previous cam is spec'd for 350 cubes; now he's going 383.
