Rev limit on ARP rod bolts?
I've been playing around with tuning my car. It has a fresh 355 bottom end with forged pistons and ARP rod bolts. I understand the heads may not make power all the way to 7k but I've done a few pulls and it seems to pull hard all the way.
my question is, how far should I push the bottom end on a regular basis. I'm not getting any real knock and the tune is in my opinion on the safe side at the moment. I was thinking of shifting at around 6700-6800k. Anybody here pushing their luck on a stockish bottom end? Lol
Your rod bolts won't be the weak point....the springs would be more of a concern for me at that RPM...especially if they have over 10k mi on them mi on them
918's have been known to break....sadly I found out
I have read WAY more 918 spring failures than any other spring. Lloyd Elliott will not buy, sell or install them due to the failure rate. When a single spring breaks...the engine damage involved typically goes WAY beyond just a bent valve.
I like many got them years ago and did check them at 5k mi intrevals....one of mine became a 2 piece spring. Fortunately the retainer was holding that coil together as it separated in my hand when I pulled the spring
springs are wear items with aftermarket cams...
Consider the Lunati LT1 kit when you decide to replace the 918's
