Tsp Ms3 Vs. Gm 847
I just heard a TSP MS3 cam in a LS1 and that shaft sounds F*c*in NASTY. I think the specs on the TSP MS3 are 237/242 & .603"/.609" LSA 113 VS. 234/242 & .575"/.595" LSA 112 My question is not to really compare a LS1 cam to a LT1 cam, but would the GM847 sound remotely as good as the MS3 cam. I really want the GM 847 to sound like a NASTY stick on a LT1...
Also the GM847 cam would be in a stock short block LT1 with 10.4 CR with all the bolt-ons, long tubes, etc. I will probably be changing out my B&B Tri-Flo for the TSP true duals. Anyone care to elaborate on RWHP with this setup and lots of tuning...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Moderator
Originally Posted by METALBEAST
With that tight 112 LSA, long duration and high lift, it should sound absolutely EVIL ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Brettinator had that cam before, I uncapped his exhaust once just to hear it, he had it with jet Hot LTs, sounded sick. Same with a CC306, LT1s generaly sound better than LS1s. A good cammed LT1 will sound mean as hell.
Vid of a GM847 through a Borla
http://spdfreakls1.com/videos/LT4MULA.wmv
clicky here
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
What's up Jeff, the car sounds Mean with a capitol M ! I'm assuming this is a solid cam ?? Well, I figured it was time to depart the world of stock bolt-on LT1's and have some fun ... I'm sure well meet up this coming summer for some T-town fun.
I'll bring my steppin shoes !!!
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Here's a clip of my car/cam, you can hear the lumpy idle pretty well. And it idles at 1050 ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
http://www.slowls1.net/video/SGMP.12.5.04/spinner.mpg
old setup
I have the GTP-6 ground on a 114 and it sounds absolutely nasty.....a 112 would have even more "chunk" to it.
I hope your heads are worked though....some folks with the GM847 / GTP-6 have been seeing 390-415 (I think is the highest I've seen). All depends on the heads and the tune.
Hey Jeff, do you think ed wright can handle tuning the GM847 cam or should I look for someone else to tune the bird ?? Ed can be a little funny about tuning if you don't let him have his way .... If I take the car to him again I want to make sure he can tune this cam correctly and give this cam some decent street manners.
i used to have that cam you have ( thats if its the same one you listed on your cardomain site) loved it but wasnt enough for the stroker
old setup
old setup
you sadi street manners
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
old setup
old setup
CC305, 1.6 Crane Gold Rockers, 3000 Stall, 3.73's, Tuning, hooker long tubes, SLP 2otl, single cutout, LT4 KM, PCMforless Tuning, shift kit...pretty much it..Your from Tulsa right?? I wanna come run up there when i get back...Thunder Valley isn't the best..Gonna have slicks when i get back to run on so should go faster...
