For $14, 6 hp... is this legit?
go out and get some bigger hosing and pull the two lines off...put bigger hosing over the two lines...and tighten down with hose clamps thats how i did mine...its a FREE MOD!!!!!! that some ppl made a kit for b/c ppl r two lazy to try and do it there selfs
Did you bother to even click on his link to look at his Dyno #'s?
The Increased Hp's are on a graph just over 6hp. So who are you arguing with?
Now on the other hand, I wouldnt have thought that you would have that much gain w/ just the bypass and may not on every car, but he did!
I can believe it especially when the throttlebody temp cooled down as much as 20 degrees!
Dont know when this was dyno'd but Im sure it helps the most in the summer, and you may not see this gain in the winter on a cold day!
Check out WS6.com to see more dyno results and analysis.
