How 96-97 SS compare to LS1?
There were a few visual differences between the 96 and 97 SS. Most noticible is the rear tail lights. The 97 has the same rear tail lights as the LS1 Camaros. In 1996 they were called Camaro Z28/SS. In 1997 the Z28 moniker was dropped and they were called simply SS. The interior was also revised in 1997 and has a new dash and instrument cluster.
You can find the production numbers here:
http://www.projectcamaro.com/camaroproduction.htm
http://lt1tech.com/cgi-bin/ultimateb...949;p=1#000002
Buy an LS1 if you can afford it and your main goal is speed close to stock form IMHO. But you cannot go wrong with either
QUOTE]
0-60 @1/4
1996 Chevrolet Camaro Z28 SS 5.3 13.80
1998 Chevrolet Camaro Z28 SS 5.2 13.60
I don't see that much diff.
QUOTE]
0-60 @1/4
I really have never understood what people's problem is with magazine test though. They have the test equipment and experienced drivers running them.
I really have never understood what people's problem is with magazine test though. They have the test equipment and experienced drivers running them.I pulled off a 1.91 60 footer in my stock LT1 back in the day and got a 13.92. I doubt I could have gotten that 60 footer to a 1.7 or below to get a 13.4
(on the stock tires of course)Poorly driven, in my opinion is a 2.0-2.2 60 footer and that will hit a 13.1-13.6 for any LS1 (adjust for altidude of course).
Reason mags are worthless is because they print averages and adjust their times with mathmatical equations for altidude, humidity etc.
http://www.execulink.com/~hamming/fast.html
True, they adjust the times, but they do that ACROSS THE BOARD for every car they test. So therefore it is a valid comparison. If you read my previous post I stated that I remembered the article quoted above and that the LS1 actually trapped 4 MPH higher than the LT1. I am in total agreement with you that the LS1 is faster. Remember I said that even though in the article quoted, there was only 2 tenths difference in ET, the trap speed was 4 MPH faster
How are they ****? They correct for standard altitude, temperature and humidity? What is wrong with that? There times are real close. You site one bad example, I can site 20 good examples. I agree that some magazines seem to get lower times (Road & Track comes to mind, they are horrible). Car & Driver does seem to get it right most of the time and Motor Trend starting to get there. Lets not forget all the test done in Chevy High Performance, GM High Tech Performance, 5.0, Muscle Mustangs & Fast Fords. Most of those magazines publish actual drag times. Just because a car performs better or worse than your expectations does not mean they screwed up testing it. So what if a magazine got 12.7 out of a Gallardo. Maybe they are a bitch to drive. I don't know, I have never driven one, have you? The guys that did the test did. I use magazines as a reference, that is all. I race at the track and spend alot of time there during the Summer and Fall so I do have real world experience in the matter.
(and the seem to always race at E-town..which is where I race at)
Corrections do not acount for everything though, specifically traction problems. The trap speeds of all of those mags are usually pretty close though.
I have not driven a Gallardo, but seriously, a 12.7?
Becuase they publish accurate drag times, not averages of who knows how many times, how the corrected for altidude etc.
. I still agree with you, stock for stock LS1 > LT1
I don't think either of us are going to change our minds. Guess we're both too stubborn
That is..2.7 60 footer style.
I not only have not quoted magazine times, I argued their non-validity.
Instead of post whoring (your post was an entire post comprised of "gets to bitch about what other people post section") and calling another member out who has almost double your posts (and if they counted racers louge and street racing posts, I would have well over 4000) and read the thread.
Have a nice day.
Misinformation. BAD misinformation. My car stock went better then 13.8, A poorly driven LS1 can go 16.0, and the best an LS1 will do isnt relavant to the case in point. Is there anything about your post I missed? On darn, post whoring. That my first, and this my second irrelevant post in LT1 tech, because generally I havent had a reason to flame anyone for making a bad post and/or series of posts. You've changed that. Have a nice day.
