Calculating Compression Ratio
Old Jan 14, 2005 | 01:05 PM
METALBEAST's Avatar
Lightbulb Calculating Compression Ratio
Compression ratio is a term that all of us are familiar with, but very few of us really understand. Whether we are milling down stock heads, swapping for some aftermarket ones, changing the stroke, the pistons or just simply using a thinner head gasket, changes to you engine combo have a profound affect your compression ratio and, consequently, on overall performance and drivability. With that in mind, I developed and easy to use formula to calculate compression ratio.
Compression ratio is defined as "the volume of the cylinder at BDC (bottom dead center) divided by the volume of the cylinder at TDC (top dead center).
CR = (Vbdc/Vtdc)
Without getting into too much detail, we can expand this to the following equation:
CR = [{(B/2)^2 * S*Pi}+Vcc+Vp+{(B/2)^2*Pi*(DH+TG)}]
[{(B/2)^2*Pi*(DH+TG)}+Vcc+Vp]
Where:
CR= Compression Ratio
B = Cylinder bore (Stock LT1 = 4.00in)
S = Stroke (Stock LT1 = 3.48in)
Vcc= Combustion Chamber Volume (Stock LT1 = 58cc = 3.539 in3)
Vp= Piston Volume (Stock LT1 = 4.5cc = 0.274606 in3)
DH = Deck Height (Stock LT1 = 0.015 in)
TG = Head Gasket Crush Thickness (Stock LT1 = 0.05 in)
Pi = 3.1415
As long as all other variables remain constant, you can change a single variable (for example larger/smaller combustion chamber size) to determine your new Compression Ratio.
*Convert Cubic Cenimeters (ccs) to Cubic Inches (in^3) using the following formula
in^3 = (CCs/16.387064)
Old Jan 14, 2005 | 07:43 PM
Vendetta's Avatar
Sticky material.
Nice job Jeff!
Old Jan 29, 2005 | 07:44 PM
seal's Avatar
acording to this thing i have 19.4 compression
no wonder why math is my worst subject lol
it took me like an hour to figure out too
Old Jan 29, 2005 | 07:51 PM
METALBEAST's Avatar
Check your numbers again. The formula works
Old Jan 30, 2005 | 11:48 AM
seal's Avatar
http://www.ls2.com/forums/showthread...5&pagenumber=1
a 4 page arguement about this subject, they are argueing bout how wrist pin location can make a diff etc, worth a read
Old Jan 30, 2005 | 02:48 PM
METALBEAST's Avatar
I really wish that Quad Cammer guy had examined the formula. The compression height is what I call Deck Height. Its included in the formula.
Old Feb 21, 2005 | 12:05 PM
BRENTT94Z's Avatar
That sucks!
This formula says I have 13.5:1 compression,
and to think I want to run boost.
Old Feb 22, 2005 | 06:13 PM
METALBEAST's Avatar
Originally Posted by BRENTT94Z
That sucks!
Must be some numbers wrong that were put in. I know this formula works. And I know you don't have that much compression Brentt. Hmm..I am assuming it is the DH number that might be messing things up. PM me your numbers Brentt and I will work on it tommorrow.
Jeff
